Ok, i have been looking for some injectors for my 2.2 ohv. All i need is about 30-34lbs cuz im not using big boost. I found a set of mazda injectors form a 626 turbo really cheap and was wondering if they would work? I know alot of domestic injectors will work as just plug and play as long as they have 2 prong plugs, and seeing as mazda is a division of ford maybe they are generally similar . Basically i need to know what will and wont work...
Based on the info in your profile, you have side feed injectors... They will not work.  Do a search on the top feed conversion...
P&P Tuning
420.5whp / 359.8wtq
Its for my 98 sunfire, with top feed injectors
RC injection sells 37 lb injectors high and low impedance versions.
I have a 98 sunfire as well with low impedance. I think our year could be either so verify with an ohm meter and just communicate it to them.
i have 4 new accel 32 lbs injectors with the bosch styl connector.  i had to buy 8 in the kit and used the other 4 on a turbo s10 project.
110.00 shipped.
Just go with some ford brown tops.... cheap and a direct fit/connect to harness.
i was looking at some brown tops, thats probably what im going to get. What about the saab 900 or 9000 turbo injectors? they are dirt cheap also... Will those work? (as direct fit)
nah, im looking for something at a minimum of 30lbs and id prefer more than that. oh and id like to spend under $80.... where or how could i find out on the saab injectors (other than trial and error)?
