Having Some Internal Wastegate Issues... - Boost Forum
Sunday, August 01, 2010 10:24 AM
I have a T3T4 with an internal wastegate. The old 8 psi wastegate I was running hit 6 psi till about 6000 then climbed to 8. I put the 10 psi wastegate in and now it runs 4 until about 6500 then climbs till 10. The vac line is t'd off another line, and I replaced that with a fresh vacuum line and no luck. Anyone have ANY advice?
I am very confused
LE61T PTE6262 Powered
Re: Having Some Internal Wastegate Issues...
Sunday, August 01, 2010 11:24 AM
Note: it was originally attached to the T for the Map and intake manifold, then i tried straight to my vac block, worse, then I tried from turbo to WG, No change. I am adding in a boost controller no, otherwise I am switching back to the 8 psi gate
Edit#2 - Added BC in and no change until it was screwed in a lot, hit 14 by accident, so I parked it and backed it out 1 turn. good enough for me
Edited 2 time(s). Last edited Sunday, August 01, 2010 11:57 AM
Sunday, August 01, 2010 6:04 PM
Roofy Online
Maybe the wastegate is binding and sticking partially open???
Sunday, August 01, 2010 6:37 PM
idk how to check that. I installed this one just like the last one
Thursday, August 05, 2010 6:41 AM
Just sounds like a boost spike from too small/large of a turbo. What are the specs?
Thursday, August 05, 2010 10:27 AM
Put the restrictor in the T-line to your boost gage if you have't already. I had that problem getting false spikes.
You can check for binding on the internal wastegate by hand if you unhook the actuator rod - it should flop open and closed pretty easily. It's just a bushing so it may have a little drag but should fully open and close by 1 finger.
You're boost signal line to your wastegate actuator should be coming right off the turbo or about a couple feet past it. You can pick anywhere in the intake tract before the TB butterfly but the closer to the TB the slower it will likely react.
