Hey guys for the Pcv I know it is illegal to run a filter   In some places because Emissions. However if I where to want just a filter for say "show purposes"  what would I ask my parts guy to Order me ?
I will upgrade to catch can when not in "show"
Hmmmmm, what engine are we talking about here? Eco?
For the eco I know you cant just buy the one from autozone because the nipple on the valve cover is too large. back when I ran a filter there I had to run it off a short hose to a reduction barb. The catch can setup I have on there now is just so much cleaner than the filter ever was.
Sponsored by:
Kronos Performance
I bough a silver spectre one at autozone. The hole was small but on the package it said it would fit. With a little effort it fit perfectly.
Hey my apologies guys yes it is for a 2.2 Eco.
Mr newb what size did you ask for ?.. I can't just tell then I want a filter right.
Hey also for my Intake air filter with the battery what filter or set-up will work?
Not sure as I am forced induction on this one..... I think the one for the pcv one that you have will work fine.
if you wanna run a filter on there for "show" then be prepared to clean the @!#$ outta your engine bay unless you swap AT THE SHOW.  Just leave it stock and be good to go. keep it clean, and people will probably like it more then some damn ricey filter anyways.
I have 2 in my tool box that I am not using and probably will never use again.
I guess I should have been nore clear. This is just I'll next pay check... I am supercharging it thus weekend.
I'm just using one there because I'm boosted and I don't want stuff going through my charger.
stuff going through the charger doesnt matter...i am running a completely stock PCV system, and lemme tell ya the car will idle better and perform better with it stock.
Yeah I need to rig up a vaccum line connection on rigged up intake to do that. I need to order one of those pieces from the K and N intake or use my stock one and move the battery to the trunk.
Actually I guess I could just use that extra port on the t/b adapter plate for autos....
Mr Newb wrote:I'm just using one there because I'm boosted and I don't want stuff going through my charger.
That's why you run through a catch can. If you're boosted, it's even more important to have a good functioning PCV since you'll be stuffing additional pressure into the crankcase when under boost (and a little breather filter is not going to help this). Use a baffled catch can, BAFFLED being the really important part, and you won't have to worry about anything recirculating through the blower.
To the OP, if you just throw a filter on the PCV nipple on the valve cover, you'll no longer have a functioning PCV system. You need vacuum to pull on the system, and that vacuum comes from the hose that runs from the valve cover to the air box.
 guys thank you for the replys. I understand the vacuum source is much preferred if not needed. I have a parts guy that has always been good to me But did not have any baffled catch cans in stock.  Was going to temp put the filter on so I did not have any oil going through the blower..
I think I shall just buy a fitting to reduce the size.
For the air intake what is the bend type that is need  (two ninety angles or can I get it as on peace?.. If yes what us it called?
Thanks again.
Ok so I'll go get a host tonight and an adapter to fit it up to my t/b? Will that work?
shayne godding wrote:guys thank you for the replys. I understand the vacuum source is much preferred if not needed. I have a parts guy that has always been good to me But did not have any baffled catch cans in stock.  Was going to temp put the filter on so I did not have any oil going through the blower..
Thanks again.
I don't think you really understand. The vacuum source isn't just preferred. You NEED it for the system to function properly. This is especially critical with a supercharger/turbo since youre adding pressure to the crankcase. It WILL NOT properly vent with a breather. End of story.
Haha either way I was just looking for a part number  or sizes for the filter until I get the catch can.
An no i do not want blown seals however for the time being it was what I was lookig for.
Part number for a catch can? How diy are you? If you cant make things yourself, there are some great baffled catch cans in the 150 dollar range, I forget the brand but they're huge with the corvette and camaro guys. Or you can get the 20 dollar one off ebay and put your own baffles in it.
Sponsored by:
Kronos Performance
Read the post  I dd not say i wanted apart number for a catch can!!!
EVILution (KGM Godfather) wrote:I don't think you really understand. The vacuum source isn't just preferred. You NEED it for the system to function properly. This is especially critical with a supercharger/turbo since youre adding pressure to the crankcase. It WILL NOT properly vent with a breather. End of story.
And when we're boosting, where exactly are we going to pull
vacuum from for the PCV to function correctly? If your air filter is not restricting flow, there isn't that much suction if one were to tap off the air intake tubing. It's very minor, compared to the amount of pressure you're implying we add to the crankcase.
And how exactly is pressure being "added to the crankcase" when you're boosting? I didn't realize there were no pistons/rings in the way and all that boost/airflow just goes right down into the block.
2001 Olds Alero (LD9)
650 whp / 543 ft-lb
@turboalero
Yes, I know what blow-by is. You quoted "a
small amount [...] escapes around the piston rings." I have always vented my PCV system with no connection to the intake, and had no adverse issues. I'm sure it is better to have a slight suction to positively pull the gases out, but it is not
 critical. The pressure in the crankcase is higher than that outside of it, so naturally the pressure will move to a lower pressure area. In an air intake tube, the pressure isn't much lower than atmospheric, if any at all. The movement of the air through the tube will affect the draw though.
650 whp / 543 ft-lb
@turboalero
And its not just the relative pressure difference. the bernoulie effect also generates a vacuum when its in your intake tube. That is why only old cars their pcv system was just a hose that dropped down under the engine and the bernoulie effect vacuum from the air just passing across end of the hose worked as the pcv.
Sponsored by:
Kronos Performance
