Im gonna keep all my questions in here, instead of creating new posts all the time.  First question, I took my coolant temp sensor out and went to install it into the Saab coolant housing, but its too small.  Can I just use a Saab one from Napa??  This is the only question at the moment as im going really slow with it right now.  Thanks alot!!!!
I make aluminu saab water tees that allow for this. Please om me if interested, this is how I did mine.
What's the difference in the Saab housing compaired to the cav one?
There is a thread difference in these..... The gm one for the cav is bigger. He must be changing the water outlets...?
jason norwood wrote:There is a thread difference in these..... The gm one for the cav is bigger. He must be changing the water outlets...?
Sorry I should have been more descriptive.  Yes I mean the wateroutlet/thermostat housing.  My stock 02 eco coolant temp sensor will not fit the Saab housing since its just too small for the hole.  The saab setup I have looks like its going to work I just need the sensor.  Thats why i asked if I can just get a saab sensor and see what happens.  Also, what did you guys do as far as a oil return and pickup??  Maybe help me out with some pics??  This is my first turbo install and my first time doing anything like this, and I wanna make sure I do this right.  I am curious to see what you coolant outlet/tree looks like Jason.  Also, on my saab outlet it goes to a straight outlet and looks like a hose is suppose to connect there.  On my stock stuff my water outlet from my radiator goes to a long pipe then behind the block into the thermostat housing/heater core lines.  What did you guys do to get around this?  Cut the pipe off the stock housing and then just find a 90* hose, or what??  Thanks again guys!!!!
I used the same supply for the oil as the saab did and I drilled a return just like the saab had, engine was out, email me at gmto2nr@yahoo.com for pictures of the tee's the supply is in the upper rad hose and the return is in the heater core hose, just like the saab , but aluminum instead of the saab plastic design that fails.
Ahh okay, Ill see if I can figure it out.
Also, I am wondering, is there any one out there that makes the three bolt exhaust manifold flanges.  Just the flanges.  Were gonna make a external wastegate.  But I need to get two flanges to make a spacer.  If you guys have any ideas it would be great.  thanks!!!
Yep, I make a 3 bolt flange also sir.
Really!  Do me a favor, send me a email, with what material you make it with and how much it would cost me for two of them.  Mikezayed02@gmail.com  thanks bud!!!
Ya pm me and I can do that , don't really use my email much. PM me tomorrow and I will look it up when at home,
Thanks
50 for 2 shipped. 3/8ths steel. Unless you need thicker. That is what I used.
