I purchased a Garrett 3071R BB turbo and I was just curious as to what size fittings you guys suggest on the:
oil inlet -
oil return -
water inlet -
water return -
Turbo is mounted just above and behind cam tower.
4 feed with restrictor
6 water
10 drain
RIP Cpl Derek Kerns And Cpl Robby Reyes
24th MEU VMM-261 (REIN) V22 Crewchiefs
11 April 2012 Morocco (African Lion)
If you guys could check these links out and tell me if I am headed in the right direction, that would be great.
oil feed
water feed
drain x2
And the appropriate flanges for the turbo as well correct?
Ok I know I asked this before,  but on to a different turbo now. This is a journal bearing and i was guessing that it needed bigger lines, but thats why im asking..thanks guys!
if journal bearing, go -4 with no restrictor.
