So I just picked up a 2 bar map sensor from my dad, which they use them on turbo 8.1's at his work.
I just checked GM Parts Direct for the price......... GM PART # 9359409....... GM LIST: $70.54/OUR PRICE: $35.27
Opposed to the S/C map..... GM PART # 9350899......... GM LIST: $240.16/OUR PRICE: $120.08
The only thing I noticed, is what gmpartsdirect calls the two. S/C Map = BAROMETER SENSOR, Other Map = MAP SENSOR
I also just noticed I've had the S/C map on our drag car...... and it ran fine with the '95 computer, but wouldnt run fine with the stock 2k computer program..... ?
Anyhow...... just thought I would throw that part number out there for you guys.
Should work on 2200, 2.4, and EcoTecs........ if you have a reflash/program and boost.....
<br>
SPD RCR Z -
'02 Z24 420whp
SLO GOAT -
'04 GTO 305whp
W41 BOI -
'78 Buick Opel Isuzu W41 Swap
What is the exact application?
My concern is that if it is a diesel application it may (and I stress may) not have negative pressure capability. Also, alot of modern diesels are running pretty high boost. So it may truly be a 2 bar sensor but its usable range would be 0-30 psi instead of the -15 to +15 used on gas engines.
Just curious. <br>
sig not found
Its a Vortec 8.1 big block gas engine (same found in Silverado and Avalanch), that they twin turboed for generator applications..... it runs 2 small turbos, and is rev. limited to about 3.5-4k rpm..... (peak torque) The motors are stock except for a special cam from GM, and that they run on bi-fuel (not diesel).
I should sneek some pics of some of the stuff at his work........ HUGE turbo's, HUGE intercoolers...... all kinds of crazy stuff.
<br>
SPD RCR Z -
'02 Z24 420whp
SLO GOAT -
'04 GTO 305whp
W41 BOI -
So a s/c 2 bar will run on a stock 95 computer? Know if it will run on the OBD2 version on the 95 computer? <br>
Cardomain|
Myspace
This is the part number for a standard 1 BAR sensor. You can find this number by looking for a MAP sensor for almost any 96 and newer vehicle so equipped.
If those turbo 8.1's are using a MAF sensor, that's probably how they're controlling the fuel. Since generators are usually run within a narrow RPM range, it's possible that the timing (usually controlled by MAP) is just set for very low amounts of advance.
-->Slow
They are not using a MAF sensor on them (Mass Air Flow), just the MAP sensor. I've seen the programing they use, and the map does read boost....... and does correct for the boost....... changing the Spark and Fuel maps....... unless thier as smart as RSM, and can make a 1 bar read boost.......... I'd have to say they are 2 bar maps.
The only app. I can find it listed for is the N/A 3.8 MFI engine....... which doesnt mean its not a 2 bar capable MAP.......
I did learn the 2.3 computer doesnt like the 2.4 map sensor...... but it does like the S/C 2.4 map senor.
16254539 is the part number for the S/C 3800 engine........ but I dont have a price on that one......
<br>
SPD RCR Z -
'02 Z24 420whp
SLO GOAT -
'04 GTO 305whp
W41 BOI -
quick question... when Gm says 1 bar... does that mean vacuum to atmosphere? so like.. -20psi to 0psi? and then the 2 bar would be up to 14.7psi ABOVE atmosphere meaning a true 29.4psi but a boosted 14.7psi?
<br>
Turbo @ 7psi... Timeslips coming soon MSN: Senior (thesenior@hotmail.com) AIM: S3nior
<img src="http://www.j-body.org/registry/thesenior/S3NIORS1.jpg">
www.acdelco.com-->parts catalog-->competitive cross reference-->enter part number 9359409, click "find parts"-->select 213-796 Sensor,MAP-->find usage
search results: 867 vehicles
Looks like Delco standardized several part numbers into one common number. Which means they have to match in specification. I can verify in service information that many of the 867 vehicles in the list have 1 bar sensors. Not tryin to be a prick, just trying to figure out some part numbers.
The sensor from the 3.8 supercharged is the large square style sensor. gmpartsdirect lists 16006835 for an 89 Sunbird turbo. This might be worth checking. gmpd pricing is about $38.00. I know that the current part listed for the turbo 'bird is the same as the 6.5 turbo diesel. It may be found cheaper as AC Delco 213-1520
9350899 (from the GM S/C kit) is originally used on the Duramax turbo diesel. It's also used on the Topkick/ Kodiak series trucks in '04 and '05. It may be found as an AC Delco 213-951.
Then there's the old style 3-bar sensor, good for almost 30 psi boost, part number 16040749 (ACD 213-101). Gmpd pricing is $51.31 with a note that the sensor is no longer in stock. The replacement sensor is part number 12223861 (ACD 213-1562) as listed on the box on my desktop and is priced at $52.75 I'd order the old one and see what happens. : ) I have yet to find a part number for a GM 4 bar sensor.
-->Slow
SpeedRacerZ wrote:So I just picked up a 2 bar map sensor from my dad, which they use them on turbo 8.1's at his work.
I
So the truck barometric sensor is exaclty the same? plug and play? i just plugged in the gm s/c map sensor part number 09350899 and it gave me:
Chevrolet Cab & Chassis Silverado
2002-2003
All applications
Chevrolet Silverado
2002
All applications
2002-2003
2500 HD, 3500
2004
2500 HD, 3500, Eng VIN 1
GMC Cab & Chassis Sierra
2002-2003
All applications
GMC Sierra
2002
All applications
2002-2003
2500 HD, 3500
Thanks brian.
Nate
1995 Cavalier W/2k1 Engine
oops..you said it was a barometric sensor and that one was 120US.
I plugged in 9359409 and it gave me a huge list.. but calls it a map sensor like u said
But is only 36 bucks like u said.
9359409
Computer Control Sensors
MAP SENSOR
1
$36.80
$36.80
$36.80
$0.00
$9.95
$46.75
The list includes lots of n/a cars too. So its all good? thats the right one and i can buy it?
Nate
better yet, can somebody post a picture of the gm s/c map sensor for me?
Nate
That is a 1 bar MAP. I have bought and tested one and it will not work with the reflash. Just to clear things up. There is an attachment of the blueprint for this map. Only premiums can see the attachment.
Thanks for testing it out for me, I have one here, just no s/c reflash cars in the area...... at least for long enough for me to test it. I asked my dad about it, and he still says its the one they use on the Turbo 8.1s to sense boost pressure.
SPD RCR Z -
'02 Z24 420whp
SLO GOAT -
'04 GTO 305whp
W41 BOI -
DCStang67 wrote:That is a 1 bar MAP. I have bought and tested one and it will not work with the reflash. Just to clear things up. There is an attachment of the blueprint for this map. Only premiums can see the attachment.
doh.. ? Cause i have to cough up the cash for the proper one. ANybody know one for sale or cheap then gmpartsdirect?
on a side note, when i was cruzing the junkyards i notesed the LD-2 have "pressher sencer" written on them like my SC map.
( no i dident cheek PN# )
weard.
Chris
'02 Z-24 Supercharged
has anyone tried it on theirs ???
im in big time need of a 2bar map its the only hold back to me putting my s/c on
I have a gm sc one for sale..........
i have/had a guy selling me 1 for 70 shipped , but i havent heard from him
i was kinda bummed when the s/c ive got didnt have a 2 bar map , it has the same part # map as my 00 came with stock
LOL
Hey guys,
back to this again.. Derek z24 said that msd 2312 will work with the reflash.. anybody esle have input on that? Heres the link to that post. Also, the just cut and attached the 2.2l map sensor connector to make it work.
http://www.j-body.org/forums/read.php?f=40&i=82191&t=82191
Thanks.
Nate
-->Slow
I thought the 8.1l turbo truck Brian was talking about wasWAS a duramax
turbo diesel.? Which turns out to be a 1 bar map sensor.
The 8.1 is the Big Block Vortec motor (GAS)....... not the Duramax......
2nd and 3rd posts in this thread address that.
SPD RCR Z -
'02 Z24 420whp
SLO GOAT -
'04 GTO 305whp
W41 BOI -
And the Duramax sensor, like the older 6.5L turbo diesel sensor, is a 2 BAR unit capable of reading from about 20 kPa to 200 kPa absolute pressure.
-->Slow
Hi, I am curious will that Chevy Silverado Map Sensor work on my 97 Cavalier 2.4L Supercharger without the flash ? Cause I swap in my Supercharger in my 97 Cavalier 2.4L. So that way I can get more boost. Will that work ? Let me know if that works.
A MAP sensor will not "get more boost". If your program is not set up for a 2 bar sensor then you should not be running a 2 bar sensor.
