ive looked and looked, talked to both summit and jegs and the only part number that seemed like it might be for a 2.4L was arp # 131-4001 ...can anyone varify this or post the correct number. thank ya. <br>
12.6 @ 114.6 MPH
Can this be made a sticky in the Boost AND Performance forums since it gets asked so frequently...
2.4L Twin Cam Head Studs
8 Qty - ATP-8.000-1LUB
Specs are - 11mm 1.5 thread pitch 8.000 long
$12 Each
2 Qty - ATP-4.165-1LUB
Specs are - 11mm 1.5 thread pitch 4.165 long
$7.94 Each
10 Qty - Nut $1.60 Each
10 Qty - Washer $0.66 Each
Total cost Direct from ARP $134.48 + shipping
Main studs 2.3 / 2.4
P/N 281-5401 $80 direct from ARP + shipping
<br>
"The FACTS are always subject to CHANGE once the TRUTH is applied"
"In the entire history of man the only stupid questions are the ones that don't get asked"
lemme get this straight, i wanna do the 2.3 head all i have to do is call ARP and tell them this number and i am se? 281-5401? or so i still need the nut and washers and lub? <br>
http://www.cardomain.com/id/StylezTA
NO , Main studs are for the MAIN CAPS on the CRANKSHAFT...
You'll still want the studs for the 2.4 head/block .
<br>
does anyone have the part number for the 2.2 ARP headbolts?
studs for ur main caps... only time i ever used them was on my small block for the windage tray... didn't think the 2.4's had em lol. Anyway, thank u <br>
could make this easy and just ask Karo to get you a set worked for me <br>
99Z24 Turbocharged (Project Mayhem)
GO BIG OR GO HOME!
Im prity sure your going to want to get the 2.3 head studs if your doing the 2.3 head swap. The 2.4 studs are 8mm vs the 10mm 2.3. So if you have the 8mm studs with a 10mm hole head. That potentially gives the head room to walk around on the block during heat cycling.
Putting the 2.3 studs in the 2.4 block is going to take some maching and re taping of the block to get them to fit though. Another option would be to use some kind of bushing on the 2.4 studs to make up the extra 2mm.
<br>
- 97 Z24 Racecar work in progress
- 04 WRX STi
ATR Crew Member
john, whos part numbers are those? arp uses a 7 digit number like you listed for the main studs.... thats the number i need only for the head studs instead.
12.6 @ 114.6 MPH
I have 6 sets left in stock for the 2.4. They are also listed on the website.
If your interested let me know . . . free S&H offered as well.. can ship out with in 24 hours.
whats your price for me? also, how much more for main bearings?
12.6 @ 114.6 MPH
stevefire23 wrote:does anyone have the part number for the 2.2 ARP headbolts?
JBP is the only place I know of that sells them...
Someone had a part number (black sunfire, chrome rims), but I think the ones he got were too short or something
________________________________________________________
-Josh
<img src=>
www.TurboTechRacing.com
We have really expanded the engine parts for the ecotec
Everything you can think of, and if we dont list it email us we most likely can get it.
-Aaron
