Finally got time to get the motor and trans. changed out.  Got it fired up this morning first shot. Idles great sounds good. Here's the list. (2.4 in case you don't know)
  .020 over bore Wiseco forged 9:1comp.
  Eagle rods
  Clevite bearings
  Balance shafts removed 2.3 oil pump conversion
  Full port and polish on the head new Stainless intake and exhaust valves
  2.3 cam (secret cams) swap
  Full balance on rotating assembly and Alum. Flywheel
  Still running the S/C with a 62mm throttle body
  RC 320 injectors
  Cartech FMU
  SAFC
  ARP Head and Main Studs
  Swapped Third and Fourth gears from a 2.2 trans. into the 2.4 Isuzu 5 spd.
  Quaife LSD
  Spec stage 3 clutch
  Stage 2 axles
  Now for the questions...
  1.  At idle the EGT's are up from the stock motor 950 or so on the stocker 1100 on the new motor. On my A/F gauge it seems to be running lean because unless I blip the throttle it will not show a green indicator light , it stays all yellows to all reds... (I know it's not the best way to tell but it's what I've got for now... BTW I backed the SAFC Lo settings to ZERO I was taking out a little (-5
 on the stocker. I do realize the new motor is going to flow more air even at idle BUT shouldn't the ECU still be able to keep up on the fuel??? Any ideas why???
  2.  Also the cooling fan won't come on now.  It ran all the time before (anytime the motor was running the fan was running. I had replaced the Sensor and the relay but it still wouldn't shut off)  Any ideas why???
  Haven't got it out on the road yet.  i still have to get all the sheet metal back on and go get the front end aligned. But should be back on the road by the weekend...
        "The FACTS are always subject to CHANGE once the TRUTH is applied"
        "In the entire history of man the only stupid questions are the ones that don't get asked"
Congrats on the swap... Sorry I cant help out though with your ?'s
Ok, #1, I'm not sure exactly what you mean, but at idle, your computer trys to hit 14.7:1 a/f.  I believe green starts a little under 13:1 (not 100% sure though), so if your seeing a steady green at idle, your idling too rich.
#2, only thing I can say here is make sure you plugged the fan back in.  Other wise, if you turn on your AC, your fan should run constant, turn that on and you can check plugs and wires to see where the power loss, or bad fan motor is.
Good luck.
2000 Z
Nice setup.
One thing I can think of on the EGT's, the RC injectors have HUGE holes in them for the fuel to spray out of......  its possibly the fuel isnt atomizing enough going into the cylinder, and there for not burning completly...... untill it reaches the exhaust manifold. That could be causing the high EGT's.  To check, just swap in the stockers (to check the idle, or light throttle) See if your EGT's go back to normal.  (not sure if these injectors where in before the engine rebuild)..........   usually the LOWER compression will lower the EGT's...... (less heat created in the combustion chamber) but maybe thats also causing the fuel not to burn entierly in the cylinder, and its continuing to burn out into the exhaust manifold.  EGT gauges are way to hard to read w/o a Wide Band to compair it against.......  I would get a Wide Band setup, and go from there.
As for the cooling fan......  is it plugged in?
    Just make sure to check the grounds..... the main ones on the front of the block.  Make sure the relay is in place.  Make sure the temp sensor is plugged in (water neck on head) Also, turn the A/C on... the fan SHOULD kick on.
SPD RCR Z -
'02 Z24  420whp
SLO GOAT  -
'04 GTO 305whp
W41 BOI -
'78 Buick Opel Isuzu W41 Swap
wow, took me 8 mins to write that?  In either case, Burnout beat me to a few of the things.........
SPD RCR Z -
'02 Z24  420whp
SLO GOAT  -
'04 GTO 305whp
W41 BOI -
My advice is to drive it around, the ecu takes time to learn.
When we first strated my current motor it ran like complete @!#$, with 320cc RC injectors the a/f was all over the place ranging from 9:1 to 20:1, lol.  It took some driving around( a couple hundred miles) keeping a very close eye on all my gauges before the ecu learned how it wanted to work together with the new motor work.
  -  93 mph in the 1/8 mile
Member of J-Body Of Michigan.
 Thanks for the help guys...  I just finished doing the fan override switch so at least I can turn the fan on.  I'll finish getting it all put back together tomorrow and give it test drive to see how it runs... Pretty pumped right now
Lower compression pistons will result in higher EGT's. This could be a factor in the higher temps.
After changing so much of the engine, I wouldn't worry about what the engine used to run, as long as the engine is ok now and within specs. Thats whats important right? Just the placement of the probe could affect the temps you're reading... so don't stress out about it. Good luck.
<br>
<img src="http://home.nycap.rr.com/xenox/jbody/jbody_shocker.jpg">
WHERE DID YOU GET QUAIFFE?? AND HOW MUCH!?
sorry... I was shocked when I red that little detail... where the hell did you find it?!?
 I got it from the group purchase that was run right here in this forum about a year ago... Didn't get it until Oct. 04 I believe.  Just been waiting for the right time to put it in. Now I can
 and
 when I dew'it.
Damn i thought u had just got it recently, cuz from what i have heard they dont make them for our cars anymore.
Check Out My Domain Page!!!
^^^ they don't I tried last month and none are avalible and they don't plan to make anymore.
Nice setup your running there, I hope everything works out for ya.
Quoth the Raven 'Nevermore
raven@accesswave.ca
Raven Autosports
55 McQuade Lake Cres,
Halifax, Nova Scotia, Canada
(902) 850-3330
10.82@132
GreenFire Online
Today 11:35 AM
I may be wrong about this, but I don't think they ever made them for J-bodies...
the quaiffe LSD is a retrofit that bolts on (I believe) from another car that has a similar transmission
john awesome setup you got there, i hope everything work out for ya.. ill be in the same boat here in alittle while
raven you tried to get a lsd for the getrag in your car and they didnt have any more??
<img src=http://registry.gmenthusiast.com/images/brandonfetter/fettersig.jpg>
R.I.P. Brian Klocke, you will never be forgotten
TheFlyingSquirrel (PJ) wrote:WHERE DID YOU GET QUAIFFE?? AND HOW MUCH!?
If you have a getrag you can buy a Quaife LSD straight from GM.
Call up quaife usa directly they should have 2-3 left in stock. $1445.00 each tho . . .
thought you told me that quaffie didnt have any more in stock karo ??
cuse i wanted 1 for my getrag
oh and i wouldnt worry about the egts , but the a/f readings i would
i say bump the fuel pressure up some and try to stay outta boost as much as possible and just drive it and break it in
[quote=97cavie24ls(JDM cav sedan™)]thought you told me that quaffie didnt have any more in stock karo ??
I was told they got 3 more in again . . . I guess now that GM buys it from them every few months they end up with a few extra ones? No clue someone told me they had more . . . best thing to do . . call and you can find out for sure . . .
TheFlyingSquirrel (PJ) wrote:Quote:
GreenFire Online
Today 11:35 AM
Nope, Quaife at one time made one for both trans's found in the 3rd Gen. J-bodies. (just so happens the trans's were found in other cars as well.)
SPD RCR Z -
'02 Z24  420whp
SLO GOAT  -
'04 GTO 305whp
W41 BOI -
