Installed the EGT gauge today.
Pegging out 1600 degree's at 9 psi, with 42 pound injectors, SAFC2 pulling 24% fuel at WOT. 2.5 turbo back to a flowmaster 40 series.
What is everybody else's EGT's driving, ect.
O noes!
yep, same here...... with the 320's and 7-8psi, I would be 1500-1600..... on the 15psi, pegged 1600 (as far as the gauge went)
The reflash retards the timing so much, that you get a flame front going threw the exhaust manifold....... works nice to spool the turbo faster, but might not be the best for the valves in the long run....... idk.
SPD RCR Z -
'02 Z24 420whp
SLO GOAT -
'04 GTO 305whp
W41 BOI -
'78 Buick Opel Isuzu W41 Swap
smokey, how you like that 3 inch with the 40 series? loud as fawk? Annoying? Or just plain cool? curious cause I am doin the same with my exhaust.
Scott
When I boost, you boost, we boost
I've got the 2.5 inch. It's actually really decent. The open dump on the wastegate on the other hand.....
O noes!
i see high egts as well on my car, hopefully when i get the emanage hooked up i can up the timing and bring those egts down some, and the open dump....omg mine is to loud im putting it back in the exhaust
R.I.P. Brian Klocke, you will never be forgotten
1600 is WAY too high
definetly address that issue or else you're going to do some major damage
my roommate rich's turbo ecotec rarely sees 1400 and this is only SPIKES so something is definetly awry... he's boosting uh a lil more than you are (I can't disclose at the time hehehe..inside joke)
