How much for that Inline fuel pump bill... I need one... I have a 250 Bhp 2200 on a stock pump....... I need an inline... Let me know
JDM Civic Hatch
Errr... Stop teasing us and tell us a price the a kit with the port fueler!!!!
Congrats Mr. Hahn, dang nice numbers!
off topic: I shot you a email about some information a few days back.
I hope to hear from you soon.
Josh
SLK 32
Contrats on the numbers!
One more time Bill, good numbers.
Now, to ask you a couple of questions, and people can think I am flaming or whatever, but I know I am not and so will you.
You said that you put down close to 350 with the 16G on 23-25psi, roughly or do I have my numbers messed up right off the bat?
Now you switch over to a 20G which considerably flows more and you have to crank it up to 28-30 psi to squeeze 50 more hp?
If the amount of flow that 20G does on 18-19 psi is the same as 16G is on 23-25 psi, you should be able to get that 50 hp from just keeping the boost the same and getting those extra 50 from cfm increase.
Now I know that even if you would TRY to push the 16G to 2Bar, it would peak out and drop off right arouns 1.6 or so, since those are the more common measurements when it comes to my DSM boys.
Another thing is about efficiency.
Last time I got the compressor maps for a 14B small/big 16G, 20G, and 25G, on a 4G63 DOHC motor they all lose efficiency at right around 1.6 Bar MAX!
2 Bar would be an inch off the top of the compressor map if you know what I mean.lol
Cfm/air flow, is uncomperable in those Turbos, but they all lose efficiency at pretty much the same point, including my T3/T04E, only Turbos that can carry past 25 psi would be Ball bearing or really big ones such as .82, .96, A/R and some gigant compressors.
So how is your Turbo efficient at 28-30psi? and why did you have to crank it up so much only not to get so much.
I am not dogging the set up by no means, and you guys have surpassed me and my set up by far, so I have no room to dis here.
For everyone that might think I am doing that, I AM NOT, just asking a couple of simple questions.
Thanks, for my future info.
Best time:"""11.946""" @ 114.73 mph @17psi 1.83--60"
11 second daily driver!!!!
Race Related 727-561-9440
Shop of choice for your 11 second J body!
Also, built bottom end and or top end LSJ and L61's available.
13's
----12's
----11's
----10's
SunCavi_L61T3/T04E wrote:One more time Bill, good numbers.
Ahhhhhh Judas speaks... j/k man just givin ya @!#$. It is an interesting question though
Ohhhhhh, Judas, that is cold. lol
I am second in line I HAVE to know. lol
13's
----12's
----11's
----10's
He would only gain power from the 20G upgrade at the same boost pressure if the 16G he was using was out of efficiency at that boost pressure. Just because its more efficient at higher cfm does not mean it is any more efficiency at lower cfm levels.
Bill, very nice numbers.
- 93 mph in the 1/8 mile
Member of J-Body Of Michigan.
WOW
E-ticket ride for sure now
good luck at the track , and get some videos for us , please
not a hint of detonation, stock computer just crying about 'misfires', LOL! (it isn't misfiring...its just working hard to fire, and thats just fine).
You mean the pesky 0300 code? I get those all the time and cant get them to go away
Bill Hahn Jr. wrote:
You can rest assured, I'd love nothing more than to strap the DFI back on, put on a killer cylinder head, a freeking HUGE turbo and downpipe, an ignition that would light up Pittsburgh,a 3" t/body, take off the air filter, maybe a shot of juice, and just get NASTY. But it wouldn't prove what I am out to prove, which is that a well-conceived set of parts can be amazingly broad in its power capability, and still be TRULY streetable, emissions-legal, and affordable.
Now that is my way of going about it.
I get it, there is more potential, from this 20G than what was brought to the table, this is just a example of what it can do.
I am also, familiar with the capabilities of different Mitsu. Turbos and the power range and those numbers would be NOT possible on a 16G.
Yes, the other Turbos would be such as GT single and duel series which easily dip past $1000 and that is waaaaaay out of MY price range and I understand any J tuner more or less.
So how does feel making your peak hp at damn near red line, I know I make mine at 6400 RPM and I shift at 6300-6400, it sucks for the next gear.
Good luck with your set up and VERY GOOD JOB.
I will be with YOU next year.
13's
----12's
----11's
----10's
Congrats and I can't wait to see the numbers and video
from this weekend.
Yup tried several different types of plugs on my ecotec to no avail, tried gaps from .030 to .050 in increments of 5, tried it with the msd hooked up, tried it with the stock ignition, it doesnt happen all the time and doesnt seem to be weather related ive gotten it anywhere from 50-100 degrees outside, my testing has only been with irridium and platinum plugs which im aware arent really ideal for boost, ive yet to try a copper plug in it i have some compatible part numbers spec wise from several different manf. that im going to try maybe this weekend. Also copper plugs are cheap as hell so its just going to take some testing to find the right one, if i have good results i'll post the p/n
Haven't noticed any immediate decrease in power but it does make me nervous that its there, I like the sense of something being "perfect" or basically without codes.
bill, i asked adam, but he wasnt sure. as far as getting past the rev limiter. wouldnt the portfueler be fine? since its not controlled by the stock ecu, it should shut off the injectors at 6500 or 108.
so once that happens and the ecu pulls fuel in the rail, wont everything still be fine with the port fueler supplying the fuel?
13 psi and climbing......
john the car would end up leaning out due to the loss of fuel from the stock injectors
So the only engine modifications are forged rods and pistons, valve springs, and retainers?
Nice #'s
