i drive a 1996 cavalier Z24 manual transmission, just to clarify.
On my way home, i stopped at a four-way  and then proceeded thru. i drove thru 1st and I shifted into 2nd(i'll admit a little hard) and it felt like it didn't all the way down. I slowly let off the clutch and i was still in 1st. tried several times will coasting home to shift to 2nd, 3rd, etc. and i couldn't go into any gear. i was able to to move the gear stick up and down but not side to side. i suspected the cable linkage so i took the center console out and checked things there. everything was fine there, so i follow the cables to were they connect to the tranny. the cable ends were not broke and no visible damage. it does feel like i am able to move into gear at the tranny, but not easily. i can not move the into neutral before i can change to another gear. i had my wife watch the gear stick as i moved the it at the tranny and it did move, so the cable is ok.
any one know what is messed up?
_______________________________________________________
J-body.org Join date: Monday, January 21, 2002
AIM & Y!: COGcaviZ24
If the cables are still in the brackets on the tranny its probably the shift forks inside the transmission.
I just cant drive 55
thanks, i was hoping it was something easier than that.  looks like i'll be doing some research to see if i can fix this myself, hopefully without having to buy another tranny
