bleed it again. make sure when you bleed it that you keep the master reservoir full. pull your starter and look for fluid. if its damp in there, slave is toast. honestly, from now on if i EVER have to pull my engine, i'm replacing the clutch, slave and rear main. too much of a pain in the ass to have to do if something goes wrong.
Been there. It's the slave.
Yeah...if you are leaking fluid from the trans it is the slave and all the bleeding in the world isn't going to fix it. The fluid is leaking from a blown seal...not something that will just go away with bleeding or pumping the pedal. Replace it and let us know if you have any further issues. Thanks!
J. Auvil
Sales and Tech Manager
www.specclutch.com
