So i ordered my top mount and tranny mount for my 97 sunfire, i know the top mount is pretty simple but not to sure about the transmission mount..does anybody have suggestions or advice that would be helpful..
Btw if u have done this before and could give me a detailed step by step that would be great
Use a block of wood on a jack to suppport the engine at the oil pan. It would be best to source an engine hoist to prevent damage to the pan.
The upper mount is easy but I would recommend using locktite on the bolts that hold the rubber mount in place. The first time I did mine they managed to eventually come out and the motor was rocking all over the place.
The tranny mount kicked my ass! The expansion bolt heard sheared off and I had to drill it out and cut it to pieces to get it out. I can't tell you how many hours I spent squatting in the wheel well and how many drill bits I went through. I was beat down after that repair!! I would strongly suggest not undertaking it unless you are 100% positive it is needs to be replaced. On these cars it's usually the upper mount and lower "dogbone" mount that go bad.
2.2 97 Cavalier......the "Crapalier"
Are you doing oem replacement or prothatne/ttr poly mount?
They arent bad the change depending on your access to tools. An arbor press makes the job much easier, I personally did my ttr poly mounts with my vise.
Most do use a vise
-Aaron
www.TurboTechRacing.com
