I just got a set of mr7's and the holes look pretty big. I went to VIP and they have a set of gorilla nuts for 30 dollars. they are tuner.. but look really really small.. is that what I need? I measure the back of the hole inside the wheel and got 7/16th of an inch.. is it the tuners that I need?
http://www.jbodytuner.com
^^ The real jbody store and forums!!!!!
yes and hub centering rings.
no thats not the size lug you need. you need the lug that will fit the stud which is 12 x 1.5 lug.
you guys wouldn't happen to know what size the hubs are on these wheels do you? For hub centric rings.. i know the cav is 57.1 i believe but I dont know the inside..
i believe all motegi wheels are 73.1mm but im not positive.
If you can fit "normal" (*not* the thread GM shyte) lugs, I'd use those.
ALOT better chances of them not rounding.
2002 Sunfire -->
- Ractive steering wheel
- ASA 17" EM9 + Nexen N5000 215/45/17 (steelies for winter)
- D-Spec Lowering kit @ 1.4" (issues currently
- Rockford P250.1 + MTX MZS1004 + Panasonic CQ-C8313U head unit
- Barely legal tint.
