Considering Cavalier's are 5x100 you would need to get adapters unless you did something with your suspension to change it. Also not sure of offset as it says 0 and I usually look at 35 to 42 range.
thanks and where can i get adapters and how much do they go for?
why not just get the correct wheel specs and do away from the adapters?  and why even bother buying 14" steel wheels?  i would suggest you read through the wheel sticky at top. and search and do some more studying before you even get close to modifying your own car.
Azncav (was static) wrote:why not just get the correct wheel specs and do away from the adapters?  and why even bother buying 14" steel wheels?  i would suggest you read through the wheel sticky at top. and search and do some more studying before you even get close to modifying your own car.
Agree with just getting the correct wheels and reading Wheel Sticky. Just search those same wheels but see if they have 5x100 instead.
I know I was just asking for an opinion thanks and I am looking for they in that size and  this ain't the first mod to my car I was just asking for an opinion like I said.
Thought those looked familiar, yup for trailer use. If you can find them in 5x100 and you like them more power to you. I am looking at 17 or 18 MSR 045 here, already know what tires I am getting because of the wheel sticky. Also found some Drifz wheels 18x7 for 200 bucks but trying to find reviews on them atm.
slightly better// but why 14s?
I gonna get them bigger than 14s
