I ordered this
Glowshift Three Pillar pod this thing is utter junk! its useless!! you cant use it. The website misleads the customer to think its a complete new pillar, which it is not! Secondly the pillar is utter garbage. There is no way it would fit over the stock trim and even if it did, there is no way it would fit back inside. The gauge pillar is made out of very hard plastic not the softer material the stock trim is which bends to fit properly into the car.
The pillar top cut finish looks like someone cutted it by hand.
I shall never buy from THIS company again and warn others, this item not even worth my trouble shipping back!
I've seen very few cavalier gauge pods that WEREN'T of the screw-on, barely-fit variety.
Cut your losses and glass it on to the pillar you have now.
thanks for the heads up saved me some money and some frustration. i was just about to put the order in till i saw this
They arent bad at all especially for the price Ive had glowshift stuff in my car for years and can honestly say they are no different from 90% of the pods and "entry level" gauges on the market.
Also no where in the ad does it mention being a full pillar replacement. And correct me if Im wrong but dont the verts have different a-pillars from the coupes?
JGM T-SHIRTS!!!!
Yes... the top area of the convertible is different from the coupe... so that may be where most of the frustration comes from.
Glow Shift is not a bad company by any means, and they don't make bad products. That particular product you mention performs just fine.
When compared to Lotek's pillar pod, it is nearly identical. Without a brand name on either one you'd hardly be able to tell them apart.
www.TaillightTinting.com #1 SOURCE FOR VHT NITE SHADES
www.aPlusPerformance.com BACK ONLINE SOMETIME SOON!
PHONE 763-682-9945
i had installed a full pillar pod with gauges in my buds 02 cavalier and never had a problem i even have a full pillar pod from glow shift in my 05 cavalier with autometer gauges and had no fitment issuse.
Don't you basically just silicone the gauge pod to the factory pillar?
no there are screws and black caps or u can just drill 4 holes and find some small push retainer.
I bought the same thing from glowshift and had no problems whatsoever installing them. I love the gauges and the pillar fit perfect like stated above 4 screws with black caps thats all you need. Are you trying to put the pillar pod on without taking your old one off first?
i think he thought it was a full pillar replacement which is what i thought it was. now that i know its not im not gonna get one
i bought a single pod and didnt have a problem with it other than i had to cut the edges the way i wanted it to fit and look. and the price is great
i got that set off ebay, no problems what so ever.
horsepower is the force that determines at what speed you hit the wall, torque is the force that determines how far you take the wall with you after you hit it.
chris b wrote:I bought the same thing from glowshift and had no problems whatsoever installing them. I love the gauges and the pillar fit perfect like stated above 4 screws with black caps thats all you need. Are you trying to put the pillar pod on without taking your old one off first?
Mine didn't come with the screws and caps. Where do you get them from?
ive install atleast 8 from them in various cars includeing the js with no problem. in most of the cars i did one in its just that pillar and looks perfect like a oem fit. if ur trying to do the coupe or sedan pillars on a drop top then thats the main issue they are wider and differant. glowshift is great with the full pods.
CAVETTE wrote:So is it a full repalcement or not?
Refer to Post #1. Not a full replacement, it is a piece of plastic with 3 gauge pods molded in that is held on to OE with screws/tabs.
FOR SALE
I tried to install my glowshift triple pillar pod today. The gauges fit in it, but the brackets to secure them didnt. Im more than likely going to toss it in the trash.
Tinkles
2003 Cavalier 1SV
Bagged and Blown
Cavette I found some in the past, I think it was made by Lotek. Don't hold me to that, just trying to help.
FOR SALE
I'll give you $5. LOL
BaggedOn20s: I'll look into the lotek. thanks for the info.
My Cardomain Page
Tinkles wrote:I tried to install my glowshift triple pillar pod today. The gauges fit in it, but the brackets to secure them didnt. Im more than likely going to toss it in the trash.
i had this problem too, but if you tinker with it a lil i got it to work
Matt Burgess wrote:chris b wrote:I bought the same thing from glowshift and had no problems whatsoever installing them. I love the gauges and the pillar fit perfect like stated above 4 screws with black caps thats all you need. Are you trying to put the pillar pod on without taking your old one off first?
Well you can go to auto-zone or lowes they will have small screws with black end caps bought separately. or you can just call glow-shift and ask for them and they might send them to you.
I didn't have to use the brackets for mine after I put them in they were in there pretty good and then on top of that my stock Pillar helped keep them in place.
I've never had to use the securing brackets as the gauges always fit snug enough to never worry.
Granted this was a Lotek pod.
