ok, ive read all the how to's and instructions, but my brackets are just not lining up right for me, and it looks like they will not alot more adjustment to even remotely fit. does anyone know if i can just buy pre-made brackets. the bolt holes on the bottom of the seats match the stock width, but are a few inches shorter. is there any kind of premade brackets that might fit this kind of application? these brackets are pi$$in me off. thanks in advance
<A HREF="http://www.cardomain.com/id/eazy716"><IMG SRC="http://registry.gmenthusiast.com/images/eazy716/personal_pic.gif" BORDER="0"></A>
Here you are my friend.
It's a write up I did a long time ago when I put my seats in my old car. Though be warned the seats may sit up higer than you personally may prefer.
thanks man, this was one of the main ones i was reading on before i tried my custom brackets. im just curious about 3 things.
1) do the seats sit higher than the stocks would, and if so, roughly how much? because my original plan was to use stock brackets and modify them, but heard about the height.
2)will stock seats ever be able to go back on those brackets after they are modified?
3) what kind of drill bit did you use to drill through that thick metal?
anyone else know of premade brackets, or an easier way to make them?
Yeah you will definitely need a bit made for steel. I used a titanium bit I found at Home Depot for 5 bucks.
http://members.sounddomain.com/02coupe
hey easy i started a how to on my car domain and my brackets were very easy to make so check it out and feel free to email me if you have any questions.
What's everyone doing with the stock seat belt latch? It's normally bolted to the stock sliders.. I'm going through this also.. Trying to find the lowest sitting option, since i'm 6'5"-6'6"...
"If life throws you a curve, pop the clutch and drift it!"
thanks for that info guys. im just having a hard time drilling the steel. i bought a cobalt bit, but it dosent even touch it, and i have no access to a welder. idk. this sux
ok, well i got the passenger seat in after alot of work, and adjusting. not looking forward to the driver seat
