ok i have a dent in my rear fender, its right in the crease of the door. I took the little plastic thing off and tried pushing it out. well i made it worse, now the paint spider webbed! does anyone know how the hell to get the seat belt bolt off on the inside rear plastic panel so i can get inside the fender!!! i tried for like 2 hours i am going nuts!!! help!! Would i jsut be better off taking to a shop and getting it cut out and have the weld a new piece in? its pretty bad now that i messed with it.
First, it's a quarter panel, rear quarter panel if you want to get specific.
As far as the seatbelt bolt, it is either a T45 or T50 torx bit. I've seen both.  Most likely it is a T45.  If I remember right, If it isn't in the right spot, you're not gonna be able to get to the dent from inside.  IMO, you should take it in if you don't know what your doing.
-Seth
