I am getting a AF and Boost gauge with my M45 kit i bought The gauges are AutoMeter Pro Comp
Where do i hook up the AF gauge? Do i just tap into one of the O2 sensors?
Also is there a way to change one of the trim rings the one on the AF gauge has a dent in it
Purple wire I believe, first 02 sensor? Info is around here somewhere, though I'm sure you know it's nothing more than a fancy light show.
Never seen anyone swaps the rings, I imagine the lense is incorporated into it. Gauge should only be $40ish anyhow? I'd personally replace it with something functional, possibly oil pressure?
Im going to replace the AF gauge with a Wideband O2 Sensor
Oil pressure would be a great idea also
Ill have to get a 3 gauge pod and have my boost, oil pressure, and Wideband
Anyone seen a good deal on oil pressure gauge?
Thanks Joe
Karo has a good deal on the Innovate line-up, if you don't mind the Inno-wait (
). I have the DB gauge with the LC1 on my way shortly... Or are you just looking to get AFR readings to log somewhere else?
I'll let you check it out when I get it, car toys always make me happy.
(I'd say ditch the boost and get a fuel pressure gauge... Unless you want to have both.)
Fuel Pressure, Oil Pressure, and AFR. That covers the heart, the guts, and the blood of the engine. Anything else, really, is for entertainment (ok, so maybe knowing what you're boosting at is *sorta* important...)
Edited 2 time(s). Last edited Thursday, February 28, 2008 8:51 PM
2002 Sunfire -->
- Ractive steering wheel
- ASA 17" EM9 + Nexen N5000 215/45/17 (steelies for winter)
- D-Spec Lowering kit @ 1.4" (issues currently
- Rockford P250.1 + MTX MZS1004 + Panasonic CQ-C8313U head unit
- Barely legal tint.
