Ok well my interior from my 97 cavalier is in HORRIBLE shape. I found a donor car that has all the pieces I need except its an 01 cavalier. Will I have a problem swapping the pieces? Im buying EVERYTHING. Seats, carpet, headliner, steering wheel, dash, center console, door panels, EVERYTHING!! LoL
Thanks in advance!
everthing will work just make sure you get the metal support behind the dash if your swaping the whole dash meaning the main part. if your just doing the top dash pad that is a direct swap
It Should fit, but you might have to modify things to make them fit correctly. A guy i know is putting the interior from a 2003 Chevy Cavalier Sedan into his 1999 Chevy Cavalier Sedan.
WI Vehicle A/C Certified Tech
Wouldn't he have some trouble since the hvac and radio are in different places?
I had the same question. Looking to obtain a full interior from a 03 cavy to put into my 98 sunfire gt...should be interesting.
it will fit a local guy here has a 98 w/ an 00+ dash... heres the pics of the swap(not a how-to)
http://www.cardomain.com/ride/506174/2
hope u dont mind me posting ur cardomain BlkCavy...
as said before as long as you are switching everything it should work... imo the 00-02 cavs/sunfires had the nicest interior.... I cannot stand the 03+ interiors they just feel cheap
Should be fine for the most part but other then the dash mentioned above the centre console has slightly diff mounting points but can be modded. I went the other way and put a 96 centre console in my 00 cause I liked the shape of the top better.
