Ok so You guys said the last post was all fed up because of my friends server so I did a Webshots Album!
Look here>
http://community.webshots.com/myphotos?action=viewAllPhotos&albumID=546632454&security=PWyBev
So tonight we got The eclipse dash back in after re-locating the HVAC controlls to the glovebox to make room for the 8" touchscreen LCD and the new HU.
I got my trunk stripped out of EVERYTHING and the rear bumper and tails off. Gotta fix some dragged-thru spots on the bumper this week and pull the old exaust.
Looking for opinions on the pace-setter system thats going on the GP?
This is how I found my pass strut when I took the front clip off, looking for Joe now to see how this warrantee works?
The missing part of my car:
The Eclipse interior with the Laptop stand, greddy boost controler in the old airbag compartment, and floor neon.
The interior of the eclipse earlier this week:
And the 8" LCD thats replacing the HVAC and OEM radio:
And 2 of my 3 old Viair 450's that im getting rid of(if anyones looking for them):
More pics later this week, working nightshift so I dont know what Ill get done.
We want the eclipse done next weekend.
Ok I have No idea why the pics in the post wont display but just follow the link, same pics just in the album?
You should have mail now.....
BTW.....Webshots has been acting weird lately.....They may have taken away hotlinking.....
I just did right-click "Show Image"
I have Mozilla tho...
Check PM's Spyder
Thats alot of work! Im doing the same.
It will be worth it! Keep up the work!
- Darren
ontariocavs.com -||- phewes.snowpants.org -||- zukiworld.com
Progress
We Got the dash back in the eclipse and everything working properly. Were gona fiberglass it in tonight but we ran outa time, Replacing his front air cylinders and front brake rotors and pads tommrow. Then I guess Ill do the glassing wensday night maybe.
On my car I finished a little bit of stock wire harness cleaning up. and fixed a big crack in one of myflares from hitting a reflector.
PIcs tommrow there on the friends camera.
Jessie is HOT
by the way cars going to look hot keep up the good work , and did i mention that jessie was hot
Shes single too
Just a friend of mine
What album are you refering to?
wow man, MAJOR props, your good at what youdo. It looks like its comming together really great. You must be dam inovative.
So ive been Buzy as hell latly with Trying to get the Eclipse and The Celica ready for the DropJaw WCT in Myrtle and havent had much time for the J, However got a LITTLE bit done.
Got the dash in the eclipse put back together and started working back on his engine, also still workong on preparing his new front air cylinders(had to make new upper and lower brackets, and Drill and port the Top of the cylinders for 1/2" ports as it had NO top ports) Also cleaned up soem of his wiring, Im Making Fiberglass "pods" for his doors now to Hold his Infinity Kappa Perfect 6.5" components.
The Celica we are replacing the heater core in(PAIN IN THE ASS) Paining the dash and INstalling his Remote start.
And last but not least In the fire I ran the new wiring for the new Valves, New Speaker wiring, Power for the massage/heated Recaro seats, power for a few of the LCDs, I relocated the yellowtop to the trunk and took out the OEM battery tray in the engine bay. I should be getting my Airtanks this week, and order my 3000PSI high pressure airlines for the SCUBA setup, also will order the tubing for the new solid airlines.
Pics can still be seen at
http://community.webshots.com/user/spyderwizard
Look in the 2-3-06 album
