I think you went too wide... Good luck...
P&P Tuning
420.5whp / 359.8wtq
Nice!! I want
M62, 42's, ZZP 3", ZZP S3 H/E
214whp 190wtq
the rims may not rub but won't the rubber hit the top?
____________________________________________________________________________
my carDomain updated 8/2/08 Forged B-day!
Good Luck Bud, you have issues already and you don't even have tires on them. I would abort mission and try a 8" wide wheel, I know I'm pushing it with my 19x8's w/35mm offset, another half inch on the inside, like I said Good luck. Seems more trouble then it is worth.
The wheels do look good.
Wow, I like the rims. But good luck with the fitment.
You cant roll the rear. Thats where the inner and outer quarter are welded together.
I seriously think you should go back and get the 7.5 or 8 inch thick version of those.
Chazz... I had to cut and file my rear quarter panel lip for my 7.5"
I ended up cutting up my tires this past year.
225/30/20
Good luck ! love'n the lip.
i cut my rear lips to clear my tires and i was running 225/40r18 and the rims were 7.5 wide but i didnt have to cut to much try and get a set of 7.5 and u wont have any problems rubbing on the struts
Looks better than stocker, but need to see them with tires.
They look awesome! Too bad for the fitment issues, roll the rears (yes two pieces come together there but you can still buy yourself a little room)
Fitment issues at 8.5, whats with that, lol. I rock 8.5's in the front and 10.5's in the rear, no rubbing issues except when the front is layed out. Granted i run a mildly different suspension setup than you
_
Now with northstar V8, IRS, 20's n 22's
i dig em, and hope all works out...
and nice jack. I got the same one
i like the rims... and @!#$ is ur car ever clean i wish mine was half as nice, seeing thoughs 1 piece headlights on ur car has made my mind up about getting em for my car...
http://corpsemangler.fortunecity.com
yes sweet rims
8 psi with m62 and IAT under 100
BALLLER! you will make it work! love the rims bro!
I did roll my rears before, so its possible. then after extending the swing arm and new wheels. I just cut them.
also you should extend the swingarm while you are at it! pleaase! its so easy for you while u dont have to do those struts brackets!
Edited 2 time(s). Last edited Friday, February 27, 2009 8:09 PM
WOW! Love the wheels
It IS possible to roll the rears but you might almost have to flare them like I did.
love them.
Needing 2.3 oil pump stuff? PM me...
Rims look good, might be time for a bbk
i like the rims. best of luck when the tire is on them!
WiGM-Tuners member.
