Shouldn't this be in the photos and media forum?
Anywho, looks good. What are the rest of your plans?
Not much really just get it running again and prolly get a lip kit on it.
JBO Member since 2006.
You have the '03 crush guard and L-bracket do-dads that comes with it?
Moar progress!
theres two upper bolts that u can use to align better.on the pad
Lookin good Jimmy
can't say i was a fan of the old kit! but, this is looking better!
WiGM-Tuners member.
lafonjef wrote:Shouldn't this be in the photos and media forum?
This IS the Photos and Media forum you tard....lol
Yes im using the 03+ crush guard with the L- Brackets that hold the bumper to the crush guard. it just doesnt seem to line well with the hood. I think the top of the bumper should be in line with the hood, but it just seems to stick out a little further past the hood. Ill prolly have to work with it some more and do some adjustments and see what i can come up with.
PFC Fox wrote:lafonjef wrote:Shouldn't this be in the photos and media forum?
I'll cut you some slack because Im sure you didnt see this in the General forum first and was moved to P&M
2012 numbers - 4SPD
AUTOMATIC!!
WHITECAVY wrote:PFC Fox wrote:lafonjef wrote:Shouldn't this be in the photos and media forum?
yes i did make the mistake of putting it into the wrong forum. lol
Jrcz24 wrote:WHITECAVY wrote:PFC Fox wrote:lafonjef wrote:Shouldn't this be in the photos and media forum?
o good, here i thought i was going crazy... well more crazy than i already am... lol
Ok here is a recent update....
I got the motor outta my DD and i pulled the red cav back into the garage.
Red Cav's new heart waiting to be installed
you should paint the engine before you install it....
DSmotorsports wrote:you should paint the engine before you install it....
I thought about it, i think ill scuff it up a little bit with a wire brush and spray some black engine paint on it.
JHand wrote:Did you fix the gap on the hood? Did you check to make sure the hood was aligned too?
Hurry and get this bish in!
Yea I fixed the gap, the hood was aligned. Im workin on getting it in as we speak, im cleaning up the engine bay a little bit right now.
Well the cav is almost ready for the road, just a couple more things to connect in the engine bay. It should be running tomorrow.
Alright here are some new things that i found that need taken care of before the car is road worthy. Once i got the motor all hooked up i found that the starter needed changed out cuz it caused the car to have a sluggish start. So today i went and changed the starter in it, then i went to go bleed the brakes, and i found that i have a fuel leak. I jacked the back end up and found that the return line is leaking, so ill need to change that out. I also decided to look underneath my DD that im parting out and i found that it has a nearly brand new gas tank, there is very very minimal rust on the tank and there is no rust on the gas tank straps, so what ill do is swap out the gas tank while i replace the fuel return line.
Alright i got the cav running and its all in one piece, it may look crappy but at least it runs and i can drive it again. Here are a couple pics the way it looks like now. ill add more pics later.
