a buddy and i are discussing what would happen if you hooked up a radiator backwards (e.g. reverse the flow).
however everything we've discussed is theoretical, has anyone ever tried it (like tried to run a pre-98 2200 rad in a 98-02 or tried running an ECO rad in a 98-02 2200)?
i would think that gravity would no longer be on your side so your water pump would be doing all the work, and there may be possibilities of air bubbles...
EDIT: well on further discussion it appears that the 95 - 97 rad is the same rad in 98-02, which would suggest reversing the flow would work, despite the gravity
EDIT 2: problem solved
: ok
: here goes
: problem solver
: all j's bleed from the same spot
: the overflow
: so
: as such
: we arent changing the highest point in the system
: and the rad will function the same as it had before
: just may take a bit more to bleed the system fully
Edited 2 time(s). Last edited Tuesday, December 22, 2009 5:39 PM
2 things.....y would u want to do this in the first place?
and y is this in the newbies section?
Yea, seriously, i was not expecting this post to be from you.
219whp - I <3 whine
im not the one wanting to do this... the question was asked to me and i really didnt know what to tell him... so i asked here if anyone else knows anything about it...
and i really didnt know what forum to post this in....
Edited 1 time(s). Last edited Wednesday, December 23, 2009 6:09 PM
