I was wondering if it was safe when at a light to press the brake fully and add gas at the same time to get a better start off the line. Would that damage anything if the accelerator is all the way down? I let go of the brake and keep the gas going an I get off the line alot better than most people out there.
Check out my car at:
http://www.Cardomain.com/ride/707929
people do that all the time
welcome to the world that I like to call auto launch. now if you figure out a way to launch higer than 3g on the stock TC give me a call
boobs now with Riboflabin"
its called a brake torque...only way to raise the RPM while doing it is a higher stall converter i believe
5K PB: 24:50
10K PB: 54:26
that is correct u need a higher stall converter. i put a 4500 on my daytona and made a big diff. don't know if they make one that hi for you're car though
People say that what doesn't kill you in this life
will make you stronger. I'm not sure if that is true
or not, but i do know one thing-You have to learn from
it and it has to make you better.......it has to.......
they do look at the post called yank stall converter or something like that in trans forum.
