Acura integra, sleeper car - Other Cars Forum
Tuesday, July 18, 2006 7:34 PM
Well my buddy gave me a deal. He's gonna trade me a 96' teg with a d15 for my beater car and 200 dollars. I think I might turbo the d15 and the d15 has a built top end with 60,000 on the bottom end. The body on the car is in rough shape(needs a new fender and repaint the rear bumper) thats why I think it would be a good sleeper. What do you all think?
<img src="http://ad.nicoclub.com/banners/nico-banner1.gif" ></a>
Re: Acura integra, sleeper car
Tuesday, July 18, 2006 7:37 PM
i think to be considered a sleeper it needs to be fast.
Tuesday, July 18, 2006 7:41 PM
Yeah man sounds like it has potential. I had a pretty decent sleeper. So much satisfactio in beating new sports cars with a car that looks like a pile.
"Custom cars, custom problems."-me
Tuesday, July 18, 2006 7:48 PM
I thought either put a b18 or k20 engine in or put a turbo on the d15
Tuesday, July 18, 2006 8:10 PM
I thought all 94+ Integra's came with B18 motors?
-Brandon
Tuesday, July 18, 2006 8:12 PM
they did, my friend swaped it with his hatch
Tuesday, July 18, 2006 9:35 PM
a d15 integra.... isn't that the exact opposite of a sleeper? Even if you turbo it, you're only making up for the power that you lost in the swap, maybe getting a little extra torque.
Cardomain|Myspace
Tuesday, July 18, 2006 11:39 PM
stock base integra comes with a 140hp b18 dohc 1.8 a d15 is the dx model thats a 1.5 sohc that makes 108 hp.. and if it was the jdm vtec d15 it makes 127hp... that engine in a heavy integra... what a waste
http://www.myspace.com/15102113
Wednesday, July 19, 2006 1:41 AM
People boost the D motor a lot more often cause it has lower compression and reacts to boost better. I know a few people with DX Civics that put out better numbers then B series with comparable setups. Yes, the Integra is heavier, but you could build it. I don't know if I'd do it, but you could put together a decent setup if you wanted to. I just think money would be better used on a more viable setup. Then again, I have NEVER seen a D motor in an Integra. It would definately be unique.
Team GREEN
Suspension Division - "Handling Before Horsepower"
Making the turns since 1999
1998 EK Civic Hatch - Yes, it's a Honda.
Wednesday, July 19, 2006 6:56 AM
RaiLS wrote:People boost the D motor a lot more often cause it has lower compression and reacts to boost better. I know a few people with DX Civics that put out better numbers then B series with comparable setups. Yes, the Integra is heavier, but you could build it. I don't know if I'd do it, but you could put together a decent setup if you wanted to. I just think money would be better used on a more viable setup. Then again, I have NEVER seen a D motor in an Integra. It would definately be unique.
It's also a lighter motor. And for everyone that hadn't noticed, it's a D16, not D15. I'm not trying to nit-pick but if you go onto a Honda forum and say "D15" there's probably going to be some pissant that'll flame you for it. Anyway... There are are a lot of D16s on the national drag circuit putting out serious numbers and in no way is it a crappy engine. Personally I'm a B- H- or K-series guy but it really boils down to displacement and your pocket book. I've also never seen a D motor in an Integra, but either way you can't go wrong with it. Realistically the 'Teg isn't all that heavy of a car, it's what around 2700 pounds or so, not muc heavier than any other car its size, and there's no reason the D16 can't handle it. Put the car on a diet and you'll fine.
Wednesday, July 19, 2006 7:05 AM
ln2johnny wrote:And for everyone that hadn't noticed, it's a D16, not D15.
Haha yeah I noticed that. D15 is old school. I had a D15 in my '89 Civic hatch. I think it was rated at 72hp from the factory lol.
Rob
Sold 2/2/05
Wednesday, July 19, 2006 8:40 AM
There are a bunch of different D15 motors AND D16 motors. I'm going to assume that when he said D15 he meant D15 which as best means he's got 102 hp (assuming a USDM engine).
I'd personally would put a DOHC (B or K peferably, an H would interesting, not sure if I've heard of anyone doing that before) back in there, but if you want to keep the D motor in there and boost it (ie work with what you have), then plan from the begining for a LOT of boost (say.. 20+psi). That'll be the only way to make it worth it. It's gonna take a decent amount of boost just to put you even with the motor that was in it to begin with so to make it a sleeper you're gonna have to go way over and above that. You may find that it would have been cheaper to swap in a DOHC to beign with.. doing something different is rarely cheap.
Wednesday, July 19, 2006 10:43 AM
well I figure I'm starting from a better platform than what I started from when I did my 2200 build.
Wednesday, July 19, 2006 11:13 AM
probably true /\
Wednesday, July 19, 2006 3:28 PM
brew-san wrote:There are a bunch of different D15 motors AND D16 motors. I'm going to assume that when he said D15 he meant D15 which as best means he's got 102 hp (assuming a USDM engine).
I don't know if I buy that line. Especially if it was a LS. (I think those came with 140ish hp stock). Either way, it all depends on what your goals are. I would check out some Honda boards and see what other people are running, their advice, ect. Good luck and keep up posted.
Team GREEN
Wednesday, July 19, 2006 4:33 PM
People dont prefer the boost on the D series because of compression. People prefer boost on the non-vtec engines over the v-tec maybe. Because if it has v-tec you have irregular valve intake.
Wednesday, July 19, 2006 4:50 PM
The compression is lower on the D series. Off the top of my head I think the D16 is aprox 9.1:1 and the B16 is 11.4:1. Don't quote me on that, as I don't have time to search. I have to goto the gym now. I will look it up when I get back.
And, yes the valve train is a little more complex, but people boost VTEC heads all the time.
Team GREEN
Wednesday, July 19, 2006 5:15 PM
People boost B-series all the time also =P The b16 takes boost really well. I dont believe its in the 11's though. I'm pretty sure its only the in the 10's but I know for a fact the B16 takes boost extremely well even for being a higher compression motor. Its just way easier to tune the non-vtec engine. Shouldn't say it handles boost better...just easier to tune and get higher boost out of.
Wednesday, July 19, 2006 9:23 PM
You are right, that was what my buddy was running on his after he got his head milled. It is 10.2 - 10.4:1 depending on the year. and by saying...
The D16 handles boost better
I mean
There are VTEC D16's as well. They had SOHC VTEC on the EX Civics. I believe the variable valves were on the intake only.
Team GREEN
Wednesday, July 19, 2006 9:27 PM
RaiLS wrote:I don't know if I buy that line. Especially if it was a LS. (I think those came with 140ish hp stock). Either way, it all depends on what your goals are. I would check out some Honda boards and see what other people are running, their advice, ect. Good luck and keep up posted.
Remember, he stated his goal was a sleeper.. sleeper to me means a car that is faster than it looks.
to get to LS power he's gonna need almost 50% more power (assuming that he's got a D15B7 and not one of the D15's that make even less power) which means roughly what? 7-8 psi? and that is just so he can be as fast as the lowest trim integra (LS) that's not much of a sleeper. If he runs roughly a 1 bar (~15 psi) (which is already a good amount of boost) he's still maybe as fast as a GSR (possibly but probably not a Type R) and that's still not much of a sleeper he's just got a GSR at that point. At 20+ psi (like I mentioned) now he's considerably faster than your average 'teg. (i.e. a sleeper)
Wednesday, July 19, 2006 9:34 PM
put in an H22a and stroke it !
Lui
Wednesday, July 19, 2006 9:49 PM
for my next project im gona find a K20 engine and swap it into the civic, u should look around man, engine swaps in imports are easy, im just lucky mine came stock with the d16 haha
Thursday, July 20, 2006 4:55 AM
ya I've gotta find somewhere to get an engine and tranny. I want a b18 with a b16 tranny. The engine thats in there now is a d15 and it was dyno'd at 126hp to the wheels. some of you are thinkin but the engine is modded.
Thursday, July 20, 2006 5:53 AM
d356(PA-J) wrote:ya I've gotta find somewhere to get an engine and tranny. I want a b18 with a b16 tranny. The engine thats in there now is a d15 and it was dyno'd at 126hp to the wheels. some of you are thinkin but the engine is modded.
That would seem to suggest a JDM D15.. or some pretty serious mods on the engine already.
Thursday, July 20, 2006 7:05 AM
the only tthing thats stock with the engine is the bottom end
