whats added with "police interceptor" mo - Other Cars Forum
Wednesday, September 20, 2006 7:51 PM
Ok well im in the market for an Fbody, and i saw a Camaro Police Interceptor, im just wondering what might be different that on a stock camaro of the same year
Re: whats added with "police interceptor"
Wednesday, September 20, 2006 8:32 PM
I know its in the cams and ecu programming seeing as I lived in between cops and I was on ride alongs with them, I also believe it has less restrictive exhaust (to an extent)
LE61T PTE6262 Powered
Wednesday, September 20, 2006 8:38 PM
upgraded suspension i believe
Thursday, September 21, 2006 5:58 AM
and usually the frame is reinforced in case of collisions
Thursday, September 21, 2006 6:15 AM
there is no difference to the motor only suspension changes
Thursday, September 21, 2006 6:22 AM
and it gets beat to hell and back.
Thursday, September 21, 2006 6:34 AM
Vincent Morris wrote:and it gets beat to hell and back.
very true....dont forget that
Thursday, September 21, 2006 6:39 AM
Thursday, September 21, 2006 2:48 PM
SlowZ24 wrote:there is no difference to the motor only suspension changes
Actually the major changes are suspension and the motor and trans are also a tad different.. Mostly cooling wise because the cars are set up to sustain high speeds for very long periods of times.
Had to change sig because some dickhead is mad it went 1 letter over size
Thursday, September 21, 2006 4:47 PM
I had GM's Police brochure book for 1996, 2000, 2002. And the only difference from a civilian Camaro Z28 to a police version Z28 was it had more wiring (computer, lights, etc) and a power steering cooler.
Now on the Caprices, Tahoes, Impalas more modified.
>>>For Sale? Clicky!<<<
Thursday, September 21, 2006 7:20 PM
B4C "Police Package"
Here you will learn all about the B4C "Police Package" Camaro. You will learn the history behind the B4C and why it was introduced as well as production numbers yearly features. You will also find a number of example B4C "Police Package" equipped Camaro pictures that you can view in full size.
The history of the The B4C Special Service Package and B4C features for each year
1995 Chevrolet Camaro B4C
"Police Package" brochure
Story behind the B4C Package ("Police Package"):
Muscle Camaro's through the years have also played a part in law enforcement. It started in 1979 when the California Highway Patrol evaluated a dozen specially prepared Z28s as high-speed pursuit vehicles.
Full-size Chevrolets had always appealed to local and state police departments for their interior room. By the end of the 1980s, however, the Caprice simply was not available with the high-output V-8s that were needed for pursuit work. Neither the TPI 305 nor 350 were available in the Caprice. Chevrolet responded to complaints heard from police departments by offering a Special Equipment Option (SEO) "Special Service Package." (RPO B4C) on the Camaro RS Coupe for 1991. Available only to law enforcement, it was basically a Z28 in RS trim. The machines retained the factory spoilers and fender flares, but the expected police-associated equipment was added. The patrol's standard-issue shotguns were shortened to fit the Z's interior. To be sure it could be easily spot, the B4C-equipped Camaro's did not come equipped with the Z28 hood blisters or high-profile rear spoiler.
These cars were a revelation to those police departments that bought them and the officers who drove them. They were no longer left in the dust but could easily pursue and overtake just about any car on the road, except maybe the Corvette or another Z28! Law enforcement journals began writing about the B4C Camaros and soon local and state police departments began including them in their annual budget requests. In that first year (1991) a total of 592 B4C Camaros were ordered. Of course, those eagle-eyed Camaro sleuths who discovered the 1LE option soon unearthed the B4C Special Service Package. Stealth Performance was born.
Production Numbers
Year
Production
1991
592
1992
589
1993
135
1994
668
1995
310
1996
228
1997
1998
1999
2000
2001
2002
What The B4C consisted of: (Year By Year)
1991
The 1991 B4C option cost $3,135 on top of the RS Coupe base list price of $12,180. It included the G92 Performance Axle package, which necessitated the choice of the LB9 305 with five (5)-speed manual transmission or the B2L 350 with four (4)-speed automatic transmission. The B4C option with the 350 V-8 cost $3,950. With either engine, the performance dual catalytic converter exhaust system was included, along with air conditioning, 16-inch aluminum wheels mounted with 245/50ZR16 blackwall tires, four (4)-wheel disc brakes, engine oil cooler, 105-amp alternator, heavy-duty 630 cold-crank-amp battery, heavy-duty electrical systems for the amount of gadgets that will be put into the car by the police department. 145-mile per hour speedometer, Z28 suspension, and the limited-slip 3.23:1 differential rear axle. The package included the base UM7 radio which could be deleted for credit, but other radios couldn't be ordered. Other options available included RPO codes AU3, A31, B34, B35, B84, C49, DG7, D27, K05 and K34. All interiors, including leather, were available. Chevrolet built 592 RS Coupes with "B4C" equipment for 1991.
1992
Very similar to the 1991 model. The 1992 B4C option cost $3,479 on top of the RS Coupe base list price of $12,075. It included the G92 Performance Axle package, which necessitated the choice of the LB9 305 with five (5)-speed manual transmission or the B2L 350 with four (4)-speed automatic transmission. The B4C option with the 350 V-8 cost $4,309. With either engine, the performance dual catalytic converter exhaust system was included, along with air conditioning, 16-inch aluminum wheels mounted with 245/50ZR16 blackwall tires. New for 1992 was the inclusion of Corvette-style front brake calipers to four (4)-wheel disc brakes. Features still included an engine oil cooler, 105-amp alternator, heavy-duty 630 cold-crank-amp battery, heavy-duty electrical systems for the amount of gadgets that will be put into the car by the police department. 145-mile per hour speedometer, Z28 suspension, and the limited-slip 3.23:1 differential rear axle. The package included the base UM7 radio which could be deleted for credit, and new for 1992, a UM6 radio could be ordered. Available with Group FCAB only. Other options available were RPO codes AC3 (after March 1992), AU3, A31, B84, C49, DG7, K05 and K34. Chevrolet built 589 RS Coupes with "B4C" equipment for 1992.
1993
This year the Camaro itself had a complete facelift. So the 1993 B4C police package equipped camaro looked entirely different from the last 2 years. There were no RS model Camaro's in 1993 so the B4C was basically a non-Z28 with the new 275HP LT1 V8 engine powerplant. The 1993 B4C option cost $3,335 for the six (6)-speed manual transmission, or $3,930 for the four (4)-speed automatic transmission, on top of the Coupe base list price of $13,399.
As in the past, there were restrictions on what could be ordered with the B4C "Police Package". And again, a manual or automatic was available. However for 1993, the manual transmissions in camaro's changed to 6 speeds. As a result, the 1993 B4C equipped Camaro could order a six (6)-speed manual or four (4)-speed automatic transmission. Chevrolet built 135 non-Z28 Coupes with "B4C" equipment for 1993.
1994
There were no RS model Camaro's in 1994 so the B4C was a non-Z28 with basically the same 275HP LT1 V8 engine powerplant. The 1994 B4C option cost $3,398 for the six (6)-speed manual transmission, or $3,933 for the four (4)-speed electronically controlled CAGS ("Computer Aided Gear Selection") automatic transmission, on top of the Coupe base list price of $13,499.
Also included with the 1994 B4C police package was a 140-amp alternator. Chevrolet built 668 non-Z28 Coupes with "B4C" equipment for 1994.
1995
There were no RS model Camaro's in 1995 so the B4C was a non-Z28 with basically the same 275HP LT1 V8 engine powerplant. The 1995 B4C option cost $3,479 for the six (6)-speed manual transmission, or $4,369 for the four (4)-speed electronically controlled CAGS ("Computer Aided Gear Selection") automatic transmission, on top of the Coupe base list price of $14,250.
Also included with the 1994 B4C police package was a 140-amp alternator. Chevrolet built 310 non-Z28 Coupes with "B4C" equipment for 1995.
1996
Very similar to the 1995 model. The 1996 B4C option cost $3,369 for the six (6)-speed manual transmission, or $4,905 for the four (4)-speed electronically controlled CAGS ("Computer Aided Gear Selection") automatic transmission, on top of the Coupe base list price of $14,990. It included a 5.7 liter LT1 V8 engine, a performance single exhaust and converter with dual tailpipes, air conditioning, and 16-inch aluminum wheels mounted with 245/50ZR16 blackwall tires. Also included were four (4)-wheel vented anti-lock disc brakes, transmission oil cooler (automatic transmission only), 140-amp alternator, heavy-duty 525 cold-crank- amp battery, heavy-duty electrical systems for the amount of gadgets that will be put into the car by the police department. As well as 150-mile per hour speedometer, performance suspension, and the limited-slip rear axle (3.23:1 automatic or 3:42:1 manual). Chevrolet built 228 Coupes with "B4C" equipment for 1996.
1997
Very similar to the 1996 model. The 1997 B4C option cost $2,474 for the six (6)-speed manual transmission, or $3,454 for the four (4)-speed electronically controlled CAGS ("Computer Aided Gear Selection") automatic transmission, on top of the Coupe base list price of $16,215. It included a 5.7 liter LT1 V8 engine, a performance single exhaust and converter with dual tailpipes, air conditioning, and 16-inch aluminum wheels mounted with 245/50ZR16 blackwall tires. Also included were four (4)-wheel vented anti-lock disc brakes, transmission oil cooler (automatic transmission only), 140-amp alternator, heavy-duty 525 cold-crank- amp battery, heavy-duty electrical systems for the amount of gadgets that will be put into the car by the police department. As well as 150-mile per hour speedometer, performance suspension, and the limited-slip rear axle ( 3.23:1 automatic or 3:42:1 manual).
1998
The 1998 Camaro received a new frontal facelift. The hood, nose, ground effects and entire front fascia was now changed. Even the lights have now been changed from set in pockets to being flush with the body of the car. The 1998 B4C option cost $0,000 for the six (6)-speed manual transmission, or $0,000 for the four (4)-speed electronically controlled CAGS ("Computer Aided Gear Selection") automatic transmission, on top of the Coupe base list price of $00,000. It included a 5.7 liter LS1 V8 engine, a performance all-welded exhaust system designed to reduce noise and vibration, and 16-inch aluminum wheels mounted with 245/50ZR16 blackwall tires. Also included were four (4)-wheel vented anti-lock disc brakes, transmission oil cooler (automatic transmission only), 140-amp alternator, heavy-duty 525 cold-crank- amp battery, heavy-duty electrical systems for the amount of gadgets that will be put into the car by the police department. As well as 155-mile per hour speedometer, performance suspension, and the limited-slip rear axle ( 3.23:1 automatic or 3:42:1 manual).
1999
Very similar to the 1998 model. The 1999 B4C option cost $0,000 for the six (6)-speed manual transmission, or $0,000 for the four (4)-speed electronically controlled CAGS ("Computer Aided Gear Selection") automatic overdrive transmission, on top of the Coupe base list price of $00,000. It included a 305 horsepower 5.7 liter LS1 V8 engine, a performance all-welded exhaust system designed to reduce noise and vibration, and 16-inch aluminum wheels mounted with 245/50ZR16 blackwall all-season performance tires. Also included were four (4)-wheel vented anti-lock disc ABS brakes, power steering oil cooler, 140-amp alternator, heavy-duty 525 cold-crank- amp battery, heavy-duty electrical systems for the amount of gadgets that will be put into the car by the police department. As well as 155-mile per hour speedometer, performance handling suspension, and the limited-slip rear axle ( 3.23:1 automatic or 3:42:1 manual).
2000
Very similar to the 1999 model. The 2000 B4C option cost $0,000 for the six (6)-speed manual transmission, or $0,000 for the four (4)-speed electronically controlled CAGS ("Computer Aided Gear Selection") automatic overdrive transmission, on top of the Coupe base list price of $00,000. It included a 305 horsepower 5.7 liter LS1 V8 engine, a performance all-welded exhaust system designed to reduce noise and vibration, and 16-inch aluminum wheels mounted with 245/50ZR16 blackwall all-season performance tires. Also included were four (4)-wheel vented anti-lock disc ABS brakes, power steering oil cooler, 140-amp alternator, heavy-duty 525 cold-crank- amp battery, heavy-duty electrical systems for the amount of gadgets that will be put into the car by the police department. As well as 155-mile per hour speedometer, performance handling suspension, and the limited-slip rear axle ( 3.23:1 automatic or 3:42:1 manual).
2001
Very similar to the 2000 model. The 2001 B4C option cost $0,000 for the six (6)-speed manual transmission, or $0,000 for the four (4)-speed electronically controlled CAGS ("Computer Aided Gear Selection") automatic overdrive transmission, on top of the Coupe base list price of $00,000. It included a now 310 horsepower 5.7 liter LS1 V8 engine and 340 lb-ft of torque (increase of 5 lbs), a performance all-welded exhaust system designed to reduce noise and vibration, and newly styled 16-inch aluminum wheels mounted with 245/50ZR16 blackwall all-season performance tires. Also included were four (4)-wheel vented anti-lock disc ABS brakes, power steering oil cooler, 140-amp alternator, heavy-duty 525 cold-crank- amp battery, heavy-duty electrical systems for the amount of gadgets that will be put into the car by the police department. As well as 155-mile per hour speedometer, performance handling suspension with revises components, and the limited-slip rear axle ( 3.23:1 automatic or 3:42:1 manual). The B4C also included Z28 bading deletion, color-keyed roof, power everything (windows, door locks, and six (6)-way power driver seat) as well as cruise control with resume feature and remote hatch release.
Friday, September 22, 2006 3:16 AM
I thought this is what comes with a Police Package
[ o ][][][][][][][][ o ] coach built jeep
Friday, September 22, 2006 9:34 AM
Am I the only one seeing "Chevrolet" on the display, but the car is a Ford Crown Vicky?
Funny though.
Re: whats added with "police interceptor" mo
Sunday, September 24, 2006 12:14 AM
99 Cavi wrote:Ok well im in the market for an Fbody, and i saw a Camaro Police Interceptor, im just wondering what might be different that on a stock camaro of the same year
A B4C Camaro is essentially the same as a Z28 but with a beefier suspension and power steering cooler and a lot lighter seeing how is had very basic options. Cloth interior, limitied power options, etc.
