BLUE SMOKE??? - Other Cars Forum
BLUE SMOKE???
Monday, October 02, 2006 8:44 PM
Okay here's the story I just bought a new car for the winter it a 1993 Toyota Tercel DXL 4 door, 4 cylinder, auto, with 137,000km. Me and my b/f went to go have a look at it last week it was mint inside and out and when we test drove it, it ran really good to, and there appeared to be nothing really wrong with it but also keep in mind neither me or my b/f are mechanics. So anyways today when we went to pick it up my b/f noticed that when I started the car a big puff of blue smoke came out from the exhaust pipe, so then he followed behind me for a while then he told me to pull over, he told me that the whole time since I started the car it was blowing blue smoke. Also when we were parked I revved up the engine and my b/f look to see what was coming out of my exhuast pipe it was a lot of black smoke from carbon build up and a little bit of water from condensation, so we figured that was normal so we started to drive home again with my b/f still following behind me to keep an eye out to see if it would still do that, but sure enough once the engine heated up no more blue smoke. But then once we parked the car for about 40min we decided to start it up again to see what would happen and sure enough blue smoke. Does anyone know what might be causing this?
Re: BLUE SMOKE???
Monday, October 02, 2006 8:53 PM
sounds like a head gasket, blue smoke is usualy a good indication of the head gasket going, letting anti freeze get through... bet if u put ur hand up to the smoke for a moment then smelled it, it would have a sweet smell to it
I just bought a 20 inch widescreen ultrasharp flat pannel..I'm going to have to subscribe to the high quality porn places now......damn
Re: BLUE SMOKE???
Monday, October 02, 2006 10:04 PM
^^^ Yup. That's usually the case.
-John
Re: BLUE SMOKE???
Monday, October 02, 2006 10:46 PM
Blue smoke = oil burning.
Re: BLUE SMOKE???
Monday, October 02, 2006 11:30 PM
oil overfill? or is that just white smoke?
Re: BLUE SMOKE???
Tuesday, October 03, 2006 4:40 AM
yup...oil burning. that's typical of older Toyotas.
R.I.P. Brian St.Germain
you know, i love when people like to criticize others about their behavior,
but turn around and do the same freaking thing months later...
Re: BLUE SMOKE???
Tuesday, October 03, 2006 1:43 PM
I was thinking oil too.
__________________________________________________
Re: BLUE SMOKE???
Tuesday, October 03, 2006 2:40 PM
JLAudioCavalier(1bad02cav) wrote:sounds like a head gasket, blue smoke is usualy a good indication of the head gasket going, letting anti freeze get through... bet if u put ur hand up to the smoke for a moment then smelled it, it would have a sweet smell to it
um, no
blue = oil
white = coolant
black = rich
always works that way.
you have oil getting into a cylinder, probably blowing past a ring. maybe a valve seal. either way, you're burning oil.
Andy
it's not how fast you go, it's how you get there that counts.
ZZP XP cam, 1.6 rockers, 105# springs, speedbuilt FWI, 3.3" modular pulley, TOG headers,
3" exhaust, flomatched injectors
'97 GTP 14.06@100.6mph pre cam w/ 3.5" pulley, I/E
Re: BLUE SMOKE???
Tuesday, October 03, 2006 4:18 PM
^ ^ ^ He's right on.
If it does it on start up and then goes away, it is most likely the valve seal leaking oil. If it puffs blue all the time then it is probably rings.
my wife 93 tercel pufs at startup and then it goes away as the engine warms up. its been doning it for over a year, don't bother rebuilding. You can get the vale seal replaced if it is consuming a lot of oil, if it's not that bad, don't bother... just keep an eye on the dipstck.
www.drluc.ca
Re: BLUE SMOKE???
Tuesday, October 03, 2006 8:18 PM
Luc Sipkema wrote:^ ^ ^ He's right on.
werd
Re: BLUE SMOKE???
Tuesday, October 03, 2006 9:26 PM
Definitely valve seals, if it goes away when warmed up.. I can't believe people said head gasket?
Red 2005 Saturn Ion-3 Coupe
Re: BLUE SMOKE???
Tuesday, October 03, 2006 9:36 PM
WORK wrote:blue = oil
white = coolant
black = rich
To add to that, white may also be transmission fluid. My Mustang had a kink in the tranny fluid line, that dripped onto the exhaust and left white smoke. Coming out from under/behind the car.
Re: BLUE SMOKE???
Tuesday, October 03, 2006 10:43 PM
Luc Sipkema wrote: its been doning it for over a year, don't bother rebuilding. You can get the vale seal replaced if it is consuming a lot of oil, if it's not that bad, don't bother... just keep an eye on the dipstck.
the wonders of an older Toyota.
Re: BLUE SMOKE???
Wednesday, October 04, 2006 12:42 PM
^ ^ ^ yeah Toyota's will keep going despite problems. I don't know what it is, but they just seem not to die. You can keep diving them with so many broken/warn parts it's not funny.
www.drluc.ca
Re: BLUE SMOKE???
Wednesday, October 04, 2006 2:02 PM
white = coolant
black = rich
that's true, tranny fluid does leave white smoke when it burns. but it's a different pattern to the smokey. it'll do it at different times than the engine will. head gasket smoke will go all the time, tranny smoke will usually only occure under load at high MPH... and of course it wont be coming from the tail pipe
Andy
Re: BLUE SMOKE???
Wednesday, October 04, 2006 2:14 PM
Let it be.
My Camaro's valve stem seals were leaking for 2 years and I had no problems.
Just change the oil when you should and you will be fine.
