Okay, The Car is a 1988 Beretta GT v6 auto.
All my lights used to work fine, one day I was slowing down and noticed a pop sound like a fuse blew then my cluster lights and interior lights shut off.
The strange thing was that my cluster and interior lights did not work but my dome light and radio still worked!
"ok i'll just replace the fuse" I thought to myself.
I Get home check every fuse, and THEYRE ALL FINE! None Blown!
"God Dammit!" What blew? I checked relays, fuse box wires everthing i could think of, I finally gave in and bought a haynes manual, well it was no help at all. I looked at a wiring diagram and it shows my "Headlamp Switch" as what is bad, well i go to the junkyard put a good one in and it starts pouring out smoke as soon as i flip the dome light on!
I was pissed at this point, I tested the 4 wires at my dimmer/dome switch to see if they had power, well I accidentally touched two of the wires coming out of the dimmer , one of them was obviously a hot wire becuase i got a spark and now my cluster lights/interior lights WORK, but ONLY WHEN my dome light switch is turned ON!!!
To top it off, they only get like half power and my dome light is really dim also like its only getting half power.
:fire
so the question is WHERE IS MY HEADLAMP SWITCH!?
I was thinking maybe a wire somewhere with a bad ground but I am confused and lost as to what to fix!
Someone please help! any comments/suggestions would be helpful!
Thanks in advance!
www.beretta.net
www.corsicas.com/forums
they might be able to help you more than we could.
