Pricing on the Genesis in the USA.
Considering everything working correctly, the Genesis' achelis heel is the engine. The Mitsubishi/Chrysler/Hyundai sourced I4 is a anchor to an otherwise competent chassis. Styling is above average IMO, and so is its interior. In 2011 the interior was spruced up a little to what was reasonable for its price interior, to an above average for its price.
If I had to buy a sporty car, this would be it, but the only thing stopping me is the I4.
A Sonata 2.0T engine transplant should be in order for this car, but with more aggressive gearing than what is found in the Sonata. The V6 needs to get the Genesis sedan's new 3.8L with 333HP/291TQ in there too. I would not mind their new 5.0L stuffed in their too.
For 2012, not much has changed. Here it is from Hyundai.
2012 HYUNDAI GENESIS COUPE
FOUNTAIN VALLEY, Calif.
The Genesis Coupe comes out fighting in 2012 with excellent rear-wheel driving dynamics, sporty interior design, good value and strong four-cylinder fuel economy. A sleek design and outstanding performance capabilities make the 2012 Genesis Coupe an attractive sports coupe package for car buyers looking to make a statement on the road.
Genesis Coupe is a purpose-built rear-wheel drive sport coupe featuring two performance-focused engines – a 210-horsepower, 2.0-liter turbocharged four-cylinder engine and a range-topping all-aluminum, 306-horsepower, DOHC 3.8-liter V6 engine.
2012 GENESIS COUPE HIGHLIGHTS
-306-horsepower from enhanced 3.8-liter V6 from Genesis sedan
-210-horsepower turbocharged, intercooled inline four cylinder achieving 30 mpg highway
-Platform-mate and sinister sibling of Car of the Year-winning Genesis sedan
-Genesis Coupe is Hyundai’s most dynamic performance car, appealing directly to the true driving enthusiast. Genesis Coupe uses the same flexible rear-wheel drive architecture developed for the Genesis sport sedan.
POWERTRAINS
Two engines infuse Genesis Coupe with performance. The 3.8-liter Lambda DOHC V6 engine delivers 306-horsepower and 266 lb-ft of torque on regular unleaded. This engine will launch the Genesis Coupe from 0 to 60 miles per hour in 5.5 seconds. To maximize the power band, the 3.8-liter engine utilizes DCVVT and a new Variable Intake System (VIS) that helps cylinders breathe more efficiently at both low and high RPM. Better-breathing results in outstanding off-the-line acceleration, passing performance and remarkable fuel efficiency. The V6 engine uses an alloy block and cylinder heads for lighter weight and thermal efficiency, and features durable timing chains with no scheduled maintenance.
The turbocharged, intercooled 2.0-liter DOHC inline four-cylinder benefits from CVVT on both the intake and exhaust camshafts. The 2.0-liter turbo generates 210-horsepower and 223 lb.-ft. of torque, with a fuel economy rating of 21 mpg city and 30 mpg highway for the manual transmission (20 mpg city/30 mpg highway automatic transmission). It also features a cast-aluminum cylinder block and cylinder head. Both engines feature a free-flowing dual cat-back exhaust and an available Torsen® limited-slip differential to put the power to the ground.
SPORT-TUNED SUSPENSION
Genesis Coupe employs a MacPherson® strut dual-link front suspension and a five-link independent rear suspension setup. The front suspension is mounted to the body via a solid subframe which is lighter and stronger than a multi-piece component. To help reduce body roll and tune the Genesis Coupe’s at-the-limit handling for maximum predictability, 24-mm diameter front and 19-mm diameter rear stabilizer bars are used.
While all Genesis Coupe models offer an engaging driving experience, the high-performance Genesis Coupe R-Spec and 3.8 Track models are the most willing partners for the true enthusiast. The track-tuned suspension features a stiffer front and rear spring rate and unique shock valving. The Genesis Coupe R-Spec and 3.8 Track models deliver a substantial increase in roll control over standard versions of the Genesis Coupe. Superb structural rigidity sets the foundation for precisely-tuned handling performance in all Genesis Coupes.
TRANSMISSIONS
Both engines are mated to a standard six-speed manual transmission. The Genesis Coupe 2.0T offers an optional five-speed automatic with SHIFTRONIC® while the 3.8-liter V6 offers a ZF® six-speed automatic transmission with SHIFTRONIC to handle the additional torque. Both automatic transmissions feature steering-wheel-mounted paddle shifters.
HIGH PERFORMANCE BRAKING SYSTEMS
Brembo four-piston calipers clamp down on 13.4-inch ventilated front brake rotors and 13-inch ventilated rear rotors on R-Spec and 3.8 Track models. All other models get substantial 12.6-inch front ventilated rotors and 12.4-inch rotors in the rear with floating single-piston calipers.
INNOVATIVE TECHNOLOGIES
Genesis Coupe 3.8 Track offers Xenon high-intensity discharge (HID) headlights. The advantages of HID headlamps include greater lighting power, daylight-type lighting and reduced power consumption.
Music lovers will welcome the Genesis Coupe’s standard auxiliary input jacks (3.5 mm mini-jack and USB input) to accommodate and charge audio devices such as iPods®. There is an optional in-dash navigation unit with a multi-gauge information display screen. This system provides new features including Bluetooth streaming audio capability. This easy-to-use unit can be controlled via a 6.5-inch WVGA touchscreen or voice-recognition by headliner-mounted microphone.
SEGMENT-LEADING SAFETY TECHNOLOGIES
In keeping with Hyundai’s focus on offering segment-leading standard safety technologies across its lineup, the Genesis Coupe includes a wide range of both active and passive safety features. Standard safety technologies include driver and front passenger advanced frontal airbags, along with front seat-mounted side airbags, side air curtains and active front head restraints.
All Genesis Coupe models feature standard four-channel ABS with Electronic Brake-force Distribution (EBD) to optimize brake performance under various dynamic loading conditions. The system also includes Brake Assist, which provides maximum ABS-level braking force when a panic stop is detected.
Electronic Stability Control (ESC), one of the industry’s most effective life-saving technologies, is standard in all Genesis Coupe models.
This focus on weight efficiency pays dividends across the board. The Genesis Coupe 2.0T sets a high fuel efficiency bar with a remarkable 30 mpg estimated EPA highway rating, because of its weight-efficient platform and its efficient 2.0-liter, low-pressure, turbocharged four-cylinder engine.
GENESIS COUPE PRODUCT HIGHLIGHTS
2.0T (6-speed MT or 5-speed AT)
2.0T R-Spec (6-speed manual transmission only)
2.0T Premium (5-speed AT only)
3.8 R-Spec (6-speed manual transmission only)
3.8 Grand Touring (6-speed AT only)
3.8 Track (6-speed MT or AT)
GENESIS COUPE 2.0T: A MORE EFFICIENT TAKE ON THE REAR-WHEEL DRIVE SPORT COUPE
Standard equipment includes:
2.0-liter, low-pressure, turbocharged, intercooled 4-cylinder engine with dual continuously variable valve timing delivering 210 hp, 223 lb.-ft. of torque (at just 2,000 rpm), 30 mpg EPA highway rating and a top speed of 137 mph
M6VR1 six-speed manual transmission (Optional: A5SR1 5-speed electronic automatic transmission with lockup torque converter and steering wheel-mounted paddle-shift SHIFTRONIC® controls)
18-inch Euroflange alloy wheels with staggered Bridgestone Potenza RE92A tires (225/45VR18 front, 245/45VR18 rear)
12.6-inch ventilated front rotors with 60mm single piston floating caliper
12.4-inch solid rear rotors with 43mm single piston floating caliper
Sport-tuned MacPherson strut dual-link front suspension and five-link rear independent suspension, 24mm front stabilizer bar, 19mm rear stabilizer bar, front strut brace
Quick-ratio hydraulic steering (2.7 turns lock-to-lock)
Electronic Stability Control (ESC) with Traction Control System (TCS)
Anti-lock Braking System (ABS) with Electronic Brake-force Distribution (EBD)
Four-wheel disc brakes with Brake Assist
Six airbags: Advanced dual front airbags with Occupant Classification System (OCS), front seat-mounted side-impact airbags, and roof-mounted side-curtain airbags
Tire Pressure Monitoring System (TPMS)
Active front head restraints
Remote keyless entry system with alarm
Driver’s lumbar support
Black-out front lower fascia
Air conditioning with outside temperature display
Dark metalgrain and chrome interior accents
Leather-wrapped steering wheel and shift knob
Power windows (one-touch up and down), door locks and mirrors
AM/FM/XM/MP3/CD audio system with six speakers
iPod/ USB/Aux jack connectivity
Steering wheel audio controls
Cruise control
Trip computer
Projector beam headlamps with auto light control
Bluetooth® hands-free connectivity with steering wheel controls
GENESIS COUPE 2.0T R-SPEC: THE ULTIMATE UPGRADEABLE, AFFORDABLE, TURBOCHARGED REAR-WHEEL DRIVE PERFORMANCE PLATFORM
R-Spec model adds or substitutes:
19-inch gunmetal-finish alloy wheels with staggered-width high-performance summer-compound Bridgestone Potenza RE050A tires (225/40YR19 front, 245/40YR19 rear)
Brembo® braking system with 13.4-inch ventilated front rotors, 42mm four-piston fixed front calipers (red), 13.0-inch ventilated rear rotors, 32mm+28mm four-piston fixed rear calipers (red)
Track-tuned suspension (higher-rate coil springs, higher-control shock absorbers, 25mm front stabilizer bar, 22mm rear stabilizer bar)
Front strut brace
Torsen limited-slip differential
Black leather bolsters with red cloth insert seats
R-Spec badge
Front camber adjustment bolt (Camber bolts included but not installed. Dealer installation of the camber bolts is optional at the customer’s discretion)
To reduce cost, weight, and complexity, R-Spec eliminates some non-essential convenience equipment such as automatic headlights, cruise control and some chrome/metalgrain interior accents.
Note: Automatic transmission not available with R-Spec
2.0T PREMIUM: HIGH DEMAND TECHNOLOGY
In addition to 2.0T standard equipment, the 2.0T Premium model adds or substitutes:
Power driver’s seat
360-watt AM/FM/XM/MP3/CD Infinity® premium audio system with 10 speakers including DVC subwoofer, eight-channel external amplifier and diversity antenna
Proximity key with push-button start
Auto-dimming mirror with HomeLink® and compass
Power tilt-and-slide sunroof
Touch-screen Navigation system
Fully automatic temperature control
GENESIS COUPE 3.8 R-SPEC
3.8 R-Spec equipment includes:
3.8-liter DOHC V6 engine with DCVVT delivering 306 hp and a top speed of 149 mph six-speed close-ratio manual transmission
Track-tuned suspension (higher-rate coil springs, higher-control shock absorbers, 25mm front stabilizer bar, 22mm rear stabilizer bar, front strut brace)
Torsen-type limited-slip differential
R-Spec badge
Multi-information display (MID)
Fog Lights
Leather-wrapped steering wheel and shifter
AM/FM/XM®/CD/MP3 audio system
iPod®/USB and MP3 auxiliary input jacks
Steering-wheel-mounted audio controls
Bluetooth® hands-free phone system
Manual air conditioning with outside temperature display
Trip computer
Power windows with auto-down/up
Power Door Locks and Outside mirrors
To reduce cost, weight, and complexity, the R-Spec eliminates some non-essential convenience equipment such as automatic headlights, cruise control and some chrome/metalgrain interior accents
GENESIS COUPE 3.8 GRAND TOURING: REFINED PERFORMANCE WITH PREMIUM FEATURES
In addition to 3.8 R-Spec equipment, the 3.8 Grand Touring adds or substitutes:
ZF® 6-speed automatic transmission with steering wheel-mounted paddle-shift SHIFTRONIC® controls
Front strut brace
Premium door sill plates
Chrome front fascia accents
Power driver’s seat
Heated driver and passenger seat
Leather seating surfaces
360-watt AM/FM/XM/MP3/CD Infinity® premium audio system with 10 speakers including DVC subwoofer, eight-channel external amplifier, and diversity antenna
Touch-screen navigation system
Automatic headlights
Cruise control
Heated mirrors with outside turn signal indicators
Backup warning system
Note: Deletes track-tuned suspension, Brembo® braking system, Torsen limited-slip differential, camber adjustment bolts, and R-Spec badge
GENESIS COUPE 3.8 TRACK: ULTIMATE PERFORMANCE
The factory-tuned 3.8 Track model deletes the backup warning system and chrome front fascia accents from the Grand Touring model, and adds or substitutes:
Black leather seating surfaces
19-inch gunmetal finish alloy wheels with staggered high-performance summer-compound Bridgestone Potenza RE050A tires (225/40YR19 front, 245/40YR19 rear)
Brembo® braking system with 13.4-inch ventilated front rotors, 42mm four-piston fixed front calipers (red), 13.0-inch ventilated rear rotors, 32mm+28mm four piston fixed rear calipers (red)
Aluminum pedals
Xenon HID headlamps
Aero wipers
Rear spoiler
Lightweight temporary spare with aluminum wheel (T135/80D18)
Genesis Coupe is available in eight exterior colors:
Karussell White
Bathurst Black
Silverstone
Nordschleife Gray
Acqua Minerale Blue
Tsukuba Red
Mirabeau Blue
Interlagos Yellow
Genesis Coupe features four different interior themes:
Black environment, premium black cloth seats (2.0T, 2.0T Premium)
Black environment, black leather-bolstered seats with high-friction red cloth insert (2.0T R-Spec, 3.8 R-Spec)
Black environment, black leather seats (3.8 Track)
Black environment, saddle brown or black leather seats (3.8 Grand Touring)
>>>For Sale? Clicky!<<<
