Hey guys,
well, i'm going to change my injector constant bc i'm  using larger injectors. 32lbs ~335cc vs the stock s/c 310cc  injectors. Looking at my stock s/c setting, it shows my injector constant as 0.32359  . Just curious if this is the same as everybody elses. I'm curious b/c with 24lbs injector the constant is 0.2xxx and i thought the bigger the injectors the smaller it stays open. Anyhow..just curious to what other stock s/c constants are and if you have bigger injectors (what size are they, and what size where they before) and what itsthe constant is  set to now.
Nate
1995 Cavalier W/2k1 Engine
doh..i downloaded another s/c tune from the bin file and its the same.
yea, I think the Reflash actually needed larger injectors, but GM just 'over clocked' the 310's to work
SPD RCR Z -
'02 Z24  420whp
SLO GOAT  -
'04 GTO 305whp
W41 BOI -
'78 Buick Opel Isuzu W41 Swap
mine ran low 13's for afr , and when i switched to 36lb and droped the fuel pressure , i picked up alot more power
