My front bumper seems to be off a little.  I'm not sure if it is from taking it off to test fit a body kit I used to have or what.  The car hasn't been wrecked or anything (although someone did bump the bumper, but this problem was there before that).
Anyone have any ideas how to fix it?  I'm including a pic of each side for comparison.  The only place it looks off, as you all will see, is by the headlight on the passenger side.  Here's the pics:
Driver's side: (nothing wrong)
Passenger side: (notice the gap?)
And if anyone from the Western PA/Eastern Ohio area wants to help me with it (someone who knows how to fix it), I will come to your house to do it.
Thanks guys.
it could be how your headlight is aligned
There are two screws that hold your headlight. I would take both off and push the headlight so that it is the way u want it. Hold it in place and then screw it back down. If that doesn't work then you can always make the holes on the headlight clips bigger until you can screw it down in the possition which you like.
you should the front of my car
 your looks fine
Darkstars wrote:you should the front of my car
 your looks fine
I'm sure there are lots of cars that look worse, but this drives me nuts (I'm a bit of a perfectionist).  I'll have to mess with it this weekend.
my car was and is still like that i brought it to the dealership and after my 3rd time i gave up
mine has those gaps on both sides, came like that.
if u figure out how to fix it please share
happy happy joy joy
Share with me too!!!! I have had a lot of problems with this. I tightened the bolts behind where the bumper meets the fender and adjusted the headlights.
I'm gonna see what I can come up with.  I may be installing new grill in the front this weekend anyhow, so I'll mess with it and let you guys know if I can fix it.
my cobalt is the same way,   except ones flush and nice and the other isnt.
