Ok i have 2 questions my first one is in order to to get the projectors to fit where the elbow comes out of the back of the headlight and rest in a plastic piece well i had to remove the plastic piece in order to get them to fit should i have done this or is there another way ???
my second question is the headlights sit where they are supposed to but when i turn them on the headlight point up too high how do you adjust them down ???
thanks for any info in advance
I had them fit by taking the plastic piece off too. Then to adjust them there's two adjusting bolts on the top of the headlights one to move side to side and one to move up and down I believe. Be careful though if you adjust them while on they might break apart cuz of the heat.
hey izn, thank you very much man that is exactly what i was looking for
im so glad that helped you out. it was funny, i had ran across that the other day by accident. i kept the addy in case someone would need it. im glad it came to good use. and so soon too.
good luck with everything man.
-Www.IznTrbl.Com-
