well i have my hids.. i noticed a couple things.. when i FIRST turn them on there REALLY bright for like 0.5 sec and then dim down and arent too good.. ive aligned them blah blah.. on the road it looks like to U's like U U with the most light coming from eeach corner of the projector instead of in the middle.. i was wondering if i need to run power straight from the battery or what to do since they turn on really bright then seen to dim a little bit.. do any of you run anything with your hids.. or just plug and play? thanx
what kind of HID's an what kind of projectors?
The power should be fine most hids take a sec or half sec to get to their operating light output. As far as the "U" it's most likley your actual headlight. I have HID's and do not have a problem what so ever.
Warning: Several things: your signature is too wide (500x200 limit), the smileys jerking off is
inappropriate and the file size of your signature exceeds the 80k limit. Please change it
before you post again.
Expires: Saturday, October 8, 2005 9:31 PM PT
the hid's being "bright" is an iilusion, its just the beam adjusting itself after being turned on.
as for the U, its the projector.
hm well that sux cuz i cant see much i just know RIGHT when i turn them on there brighter and then they dim out a little bit its like i can see the edges of the road not but right in front of my car because the stupid U
Sounds like craptacular projectors dude
so what happends if i take that metal piece out of the middle of the projector will they be any more brighter or why is it there???
That what happen's when you buy those crap projectors, My hid's were plug and play.
2012 HD VRSCF
2010 Ford Explorer
2006 Ford Ranger
2004 Chevy Cavalier
Your Projectors/HIDs should look something like this at night:
I need to get a better picture now that i've aligned them.. but you get the idea..
There shouldnt be a U shape, it should be a relatively straight line. Do you have any pictures?
that metal piece blocks off the top half of light. if you remove it, you will have 360 degrees of light shining onto the road, and mainly, into oncoming traffic. that'd be REALLY bad, it'd be like having highs on all the time.
well im forced to have my highs on now anyway so maybe it would help..lol cu zmy projectors suck like no others ive ever seen
no man, someone's gonna crash into you.
ive been driving with HIDS in my highbeams thats all i can use lol would it be better if i took out the metal piece would it be even more light then the high beams?
he allready answered that. it is not safe.
Viper98912 wrote:that metal piece blocks off the top half of light. if you remove it, you will have 360 degrees of light shining onto the road, and mainly, into oncoming traffic. that'd be REALLY bad, it'd be like having highs on all the time.
-Www.IznTrbl.Com-
