i started off be removing the tire and the inner gas filler shroud.
filler shroud gone
the filler neck is connected to the tank here.
i disconnected the filler neck and sealed the inlets to the tank using a rag, plastic bag, and a tie wrap. i did this to reduce gas and fumes(i had almost a full tank when i did it. nothing came out of the neck, but some did come out of the EVAP hose)
i then cut the neck and the EVAP tube
cut off
next i measured and cut a hole a hole for the gas cap using a whole saw (didn't have the right size so i increase the size with a dremel)
the location of the whole in the wheel well is very important! unfortunitly, i could not find a good way to predict the exact location.
guesstamation was the best i could do. (which caused some problems further on in this project)
trunk view
outside view
in order to test fit the way it sits, i had to cut the EVAP tube. seems to fit good
but the EVAP tube was preventing the trunk to shut!!! nothing that a hammer couldn't fix
i then cut a peice of the hose i bought and test fit it. found that it was really close to the tire.
another view
the solution i found was to relocate the bracket that secured the filler neck to the car
before
relocated
after
drilled whole for EVAP
last i connected everything
under the car
in the trunk
on with the bodywork
_______________________________________________________
J-body.org Join date: Monday, January 21, 2002
AIM & Y!: COGcaviZ24
i forgot to mention, i sealed anything up with some windshield sealer
post sticky worthy? considering i could not 1
full right up this mod
Do multiple body mod write ups THEN you can make it a sticky yO! Sry I couldn't drive up! My car has been losing bolts going down the highway and I'm trying to figure out where the hail the go!
N2O + Bolt-ons
= 220Hp/
250Tq
Coming Soon:HpTunersPro, EagleConnectingRods, WiescoPistons, 13sec2200
i did notice a faint smell of gas in trunk in the area were the assembly is located. i'll try to find the source tommorrow during daylight
very nice man!!! i just welded my gas door shut today. didnt start the relocation yet though, lol
how did you secure the filler nect in the hole in the trunk? weld? i didnt see any bolts
Joey Baggs (Eazy716) wrote:very nice man!!! i just welded my gas door shut today. didnt start the relocation yet though, lol
weld
oh and you should just put the size of hose you used in this post since it was posted on that other post. that sounds confusing
Is it as easy as you made it look?
it really is. other then the shaving part shouldnt take you more than an hour. ive done it once and should be doing mine soon also
yellow22 wrote:oh and you should just put the size of hose you used in this post since it was posted on that other post. that sounds confusing
filler neck hose needs to be 1 1/2 inside diameter and needs a 1/2 inside diameter.
btw, the gas cap doesn't allow the trunk to shut properly. i had shave a little off the top(handle) and tape over the hole temporarly untill i can find another solution. i'm going by autozone today to see what they have
thats why i wanna sink mine flush with the flat trunk part
i couldn't figure out how to do that without water runing down beside the gas cap and into the trunk
ya. i was wondering the same thing. thought about sealing it in there with some kind of round insert, but then i thought if i did that, water would then just sit in there which obviously wouldnt be good.
i dont drive the car even if there are clouds in the sky, lol. but for washing it and if i were to get caught in the rain, that would suck.
come to think of it dont they make those flat gas filler caps? with a pull clip kinda release?
james did his with the sparco door and it was the best filler relocation ive ever seen.
good write up, do u know if its possible to relocate to the filler panel? have yet to look and make sure it wont be a slope.
If I ever get into the body shaving thing, I'm so doing this, the antenna, filler plates under the tail lights, and door locks......
SPD RCR Z -
'02 Z24 420whp
SLO GOAT -
'04 GTO 305whp
W41 BOI -
'78 Buick Opel Isuzu W41 Swap
They acaully make a cap that you just stick the gas filler in a little hole and so you dont have to remover the gas cap..
http://www.kleenwheels.com/permacap_install.htm i know thats what im going to do when i shave mine.. there is one i found quickly i think there is nicer ones out there tho..it looks low profile enough too...phil
Edited 2 time(s). Last edited Monday, January 15, 2007 12:09 PM
solved the gas cap cearlance problem. i went to autozone and looked at all there caps, found nothing useful. so i bought the cheapest one to replace the original one that i hacked up. the resolution was using my favorite tool, a hammer!
i simply hammered the inside of the trunk lid to gain clearance
BUT!! i'm still getting a check engine light. looks like i gotta go back autozone.
i didn't use any sealant around the connections, maybe that will fix it......if not, suggestions?
hmmm, i would assume that has to be the answer. make sure them lines are completely sealed and the code should go away.
any chance you could take a pic of the filler with the cap off??
ask and you shall receive....
if anyone is wondering why you see rust in that area, it's grind shavings from other projects. i just failed to clean it up after. it wipes right off
COGcaviZ24 wrote:filler neck hose needs to be 1 1/2 inside diameter and EVAP needs a 1/2 inside diameter.
Ima goof
