I would liek to know how to disable my front signal lights when i have my headlights on. I want my turn signals only to light up when i have the blinker on. On a 97 2dr se. anyone know how to do that.
there are two wires a the bulb, cut the parkinglight onlly wire...done
3 wires
... park, turn and ground.
Cut the brown wires
*two wires for power...i figured ground was assumed
but yes, brown go bye bye
don't worry, I knew what you meant
another idea, which I came across by accident is using a single circuit bulb if you don't want to cut wires, most cheap LEDs are this way
beef wrote:another idea, which I came across by accident is using a single circuit bulb if you don't want to cut wires, most cheap LEDs are this way
Are the sockets dual filament though?
the socketa are dual filament as is teh bulb
