What is the part # for the AC Bypass pulley, and Where can I get it?
Also, where can I get the frame for the pulley to go on?
And finally, Will the GM Dealer put it in for me? Or will I have to go to a private shop?
And while I'm at, What would make a brand new Serp belt squeak? I'm talking brand new this morning. The belt is just @!#$ squeeling and it's getting annoying. Could it be related to the fact that my AC Clutch bearing is @!#$?
Ya the noise is probably the crappy ac compresser, one place i found it was RockAuto.com, and just look under Ac for your car, plus you could probably take it anywhere, and they will put it on, its not to hard, i put it on myself.
Autozone, or ebay; they have the pulley by-pass for $40.  It comes with the bracket for the 2.2OHV.  It's easy just remove the A/C compressor (carefull with the pressure, release it slowly.  this is elegall in IL) .  The install is cake.
Alfredo turbokav wrote:Autozone, or ebay; they have the pulley by-pass for $40.  It comes with the bracket for the 2.2OHV.  It's easy just remove the A/C compressor (carefull with the pressure, release it slowly.  this is elegall in IL) .  The install is cake.
Uh, I have the 2.4.........
Will the 2.2 Ac Bypass work for the 2.4 if I drill and tap mounting holes? Meaning is the pulley the same size?
Mantapart.com
OP 4519 A/C Eliminator Pulley: This special casting replaces the bracket and air conditioning compressor on 2.4TC engines and uses a stock belt. Remove weight and reduce drag for more power.
or you could just get a shorter belt like i did on both my j's. hell im too poor for all that stuff
2004 Cavalier, 2.2 ecotec, 5spd getrag
do you ever notice that the ones who talk the loudest have the least to talk about?
^^ Do you have a pic for how to route the belt?
if you have the 2.4 you have to have something there for the belt to work, you cant route the belt differnet, anything you can find for the 2.3 or 2.4 should all work together fine   I bought one from ebay but it kinda sucks, makes more noise then the ac pump i took off, so i suggest getting the one from AutoZone, its from a local store and has a warrenty, i'm going to go replace that one, for the one i have on my car,
