holy crap dude this is really good! it seems to me like this is sticky material, only thing i couldnt find is the actual diagnosis of the motor. you stated what some symptoms are but never properly diagnosed it, but other than that you did a really good job.
Author's note: I don't know if there's a "proper" way to diagnose a failing motor other than seeing it exhibit the symptoms that I describe in my post. I've had three different motors fail (on two different cars), and they all exhibited the exact same symptoms. When my first motor failed, I thought that it might be a bad switch or a bad regulator joint or something, because the window would work part of the way and then stop. (And then several seconds later it would work part of the way and stop.) I thought that if the motor failed, it just wouldn't work at all. But that's not the case. So I included failure symptoms in the "How to diagnose..." section, in hopes that it would help others diagnose the problem. There may be some way to run an electrical test on the motor, but I'd say that if you're seeing the aforementioned symptoms, then there's a 99% chance you need to replace the power-window motor.
In case it helps, perhaps I should note that my power-window motors failed after about 10 years (driver-side) and 11 years (passenger side of one car). We have Cavalier convertibles and live in northern California (nice weather most of the year) so we may use our power windows more than average, consequently burning them out quicker. They're DC motors (with brushes) so the brushes wear down with usage, not with time.
Thanks for the positive feedback. I hope my post helps others as much as other peoples' posts (about removing the center console and replacing the blower resitor, etc) have helped me. Just trying to give back to the community!
wow thanks for this thread! my 04 motor failed this fall and i am just getting around to replacing it. what a pain in the a$$. my car is not that old why did it go so fast. and i have a co-worker that had to do it on his wifes 04 sun fire passenger side like mine. they went within the same week too! when i put it together i cleaned and re-lubed the slides also just to make sure that it lasts.
see ya!
i wanted to know how long did it take you to take replace the motor time frame wise. i need to change out all my 4 motors.
thanks.
~1996 Cavalier LS 2.4L (auto)
im sorry i just read it: "This job should take about 3-4 hours depending on how lucky you get removing bolts and rivets."
Author's addendum: Information about how to diagnose and repair or replace a power window switch is
here. It includes information on how to determine whether the problem is your motor or your switch.
question, my motor goes down really normal and fast, but its going up that is slow and after while you can push button again and it moves up 1/2" and then press button later untill it finally goes all the way up.
could this be i just need to lubricate it? its just werid how it goes down fast but not up.
Letxen3 wrote:question, my motor goes down really normal and fast, but its going up that is slow and after while you can push button again and it moves up 1/2" and then press button later untill it finally goes all the way up.
I'm new here (first post), and I'm having the same problem on my wife's 2004 Cavalier 4-door. The driver's door window goes down just fine but gets stuck when going up. Waiting a couple seconds usually enables it to go up the rest of the way.
I'd really like to know if there's something else I can try before tearing into replacing the window motor. I can't imagine that a 4-year-old motor would crap out already...
2004 Cavalier ("Chloe")
Vinny Illi wrote:Letxen3 wrote:question, my motor goes down really normal and fast, but its going up that is slow and after while you can push button again and it moves up 1/2" and then press button later untill it finally goes all the way up.
these cars are known for crappy window motors. seriously crappy. from your symptoms, it's a classic motor problem.
the motor works by way of temperature (the easiest way to explain it). it knows when to stop when a certain part inside warms up (meaning heavy load/excess current draw). when the motor starts failing, it will heat up, thus stopping short of pushing the window all the way up.
Desert Tuners
Thanks for the reply. That's what I was afraid of.
Who designed these motors and doors? They should be beaten over the head with a large dead trout. I'm really not looking forward to the whole drilling-out-rivets-and-replacing-them-with-bolts thing. But I guess I'll have to suck it up, because I sure as heck can't afford to pay a mechanic 3-4 hours of labor do to it!
same here
I'll be using this guide when I pick up an actuator this weekend...
Looks plenty specific. Thanks to you Dave, backyard mechanics like me can save hundreds in labour.
Nope.
I just replaced my drivers side motor and for some reason it will not go all the way down. Any reason what could cause this?
This is a great write-up. I've done several repairs on 'vert power windows and would like to add a couple of thoughts.
1. The convertibles have front and rear upper travel limit stops, which of course the coupes and sedans (that have framed windows) don't have. The stop brackets are stamped of fairly soft metal and have plastic stops attached to them as described in the write up. Believe it or not, some aftermarket window motors are more powerful than OEM's and I've seen cases where the stop brackets have actually bent under the constant pounding they endure in normal use when the window is raised to the top. So, if you have a 'vert and have the doors apart, check the up-stop brackets for bending. I've also used self-adhesive velcro on the plastic stop blocks themselves to help minimize rattles where they contact the glass.
2. 'Verts don't have a glass run channel at the rear of the door, only a guide that is screwed to the bottom of the glass and runs on a matching rail the height of the door. The front has a glass run channel, but the glass is only supported in the channel by two plastic clips (one upper, one lower) that run in the channel. Of the half dozen or so of these doors I've disassembled, all of them had clips that had come off or broken due to wear and fallen into the bottom of the door. When the clips fall out, the glass rattles horribly in the channel when the door is closed or the car is driven. The clips are discontinued and unobtainium from GM anymore. To solve this, I got several samples of felt coated rubber window channel from JC Whitney and installed them in the front window channel to see which one would work. I finally settled on one that did the job, but there are two caveats. First, when raising the window, it actually is forced forward and up, creating a fair amount of pressure on the rubber channel. Second, even new motors don't have much power, so increasing the friction of the glass in the channel with a full length rubber insert puts a strain on the motor, which will impact it's life. I solved this as best I could by using the shortest and narrowest channel I found available (5/8" deep by 7/16" wide) and applied silicone grease on the inside of the channel where the glass would be pushed forward into it. Seems to work good and definitely secures the glass and eliminates rattles, but I plan on having to replace the rubber channel every couple of years (not difficutl).
3. If anyone asks, the 'vert door glass is different from the coupes and isn't interchangeable. (The 'vert glass is both taller and longer.)
4. The window regulators for the 'vert are unique to the 'vert. They are also extremely rare and I might have bought the last OEM one left last year. (If you find 'vert doors at a wrecking yard, you should pick them up.) The coupe regulators look identical and mount the same way, but the main crank gear on the 'vert regulator has several more teeth and provides the additional up/down travel the taller 'vert glass needs.
There are lots of coupes and sedans around, but there are quite a few 'vert body parts that are unique to that model. 3rd gen 'vert production was less than 10,000 units a year for the six years they were built ('95-'00). If you have a 'vert and want to keep the body intact, get whatever parts you can (especially doors) from the wrecking yard when you see them. You won't regret it. Good luck. - Mark
markc50...formerly 1of7627 but that login doesn't work anymore.
Author's addendum:
1) I just realized that the gold colored "rear limiter" or "rear height limiter" that I mentioned in steps #14 and #41 may only be present on convertible Cavaliers, since non-convertibles have a window frame that can stop the window from going up too high. (I'm not sure since I only own convertibles.)
2) I just burnt out my second driver's side motor. This one actually just failed completely, with the window all the way up. Since the motor completely failed I was not able to move the window up and down in order to position the nuts and bolts so that they could be accessed through the holed in the door. So I cleaned the glass and the exterior of the door and then I taped the glass securely in place (from the exterior) with several strips of high-quality packing tape to hold up the glass while I removed the motor. Then I detached the motor and regulator assembly. Then I removed the tape with one hand while holding the window up with my other hand. (You may want to get a helper for this because if you let go of the window it will fall to the bottom of the door and it will likely shatter.) Then I carefully lowered the window. Then with the window and regulator assembly lowered, I removed the two nuts that hold the window to the reguator assembly. Then I pulled the window back up and taped it in place while I removed the motor and regulator. It made me realize that it is possible to eliminate the steps necessary to remove the window (i.e. steps 9, 11, 12, 13, 14, & 15). And in fact, if you have some high-quality packing tape (or a helper) that you can trust to hold up the window, that's probably a faster way to go. Just be certain that the window doesn't fall and shatter!!!
this will be included in my vert info thread for sure. do you still have the pics? if so would you rehost so i can save or email them to me? thanks!
I found this thread via a search. Great write up. I just did both regulators and motors in both doors on a 2000 Sunfire Convertible. Got the parts from rockauto.com and the regulators were correct for the convertible.
One trick I used was to loosen the bolts that attach glass to regulators, raise it up, and then wrap thick cardboard around the glass and put a C Clamp on the cardboard to hold the window up. Just don't over tighten the C Clamp, just snug, and clamp on both the front and the back so both ends are held up. Then power the window down and remove regulator and motor assembly.
Another thing I found to get the rivets out easily is to take a miniture phillips screw driver and tap the pin out of the middle of the rivet. This makes drilling extremely easy and fast. In some cases rivet would spin just wedge a large flat blade screw driver between rivet and door to hold it still. I used a 3/8" drill bit.
Someone before me thought of a really smart trick. They trimmed the arm rest bracket so the rivet that is normally under the bracket is exposed. Now the arm rest bracket never has to be removed again.
And use a vacuum to get all the old rivets out of the bottom of the door to prevent rattles before you put the regulator back in.
2000 Sunfire GT Convertible (daughters car, totaled Jan 2014 RIP)
Bill: Great tips. I especially like the C-clamp idea. I'm glad my write-up helped. Thanks for checking back in.
I found this write-up and think it's really helpful, but I am stuck with step number 8. My motor has completely died and won't budge at all. I tried helping the window up with my hand while pressing the button, but it's totally siezed and won't move even a little bit. Is there any trick to getting the motor to release so I can move it? I can't really do anything else until I figure this out. Anyone have a similar issue?
