I assume this indicates the flasher blew on my 05 Cavi?
Also, where is it located? I checked the fuses and they are good. I looked in my HAYNES book and it does not show a location of the flasher.
the flasher is located under the steering wheel column, close to the brake way up there under the dash.
is a plastic square looking piece.
so look up under the steering wheel column close to the brake pedal.
Hey I replaced the flasher and still no FLASHERS, BLINKERS or BRAKE LIGHTS
what happens when you turn the singal on?
does it make a ERRRRR sound? do they blink fast, or does it blink normal but the lights don't work?
Nothing, no noise, no flash, nothing lights up. I replaced the flasher next to the brake pedal. I just went to KRAGENS and bought another and the guy told me one is under the hood?
maybe he's talking about the relay for the turn signals in the fuse box.
I had a similar problem with the z24 but it was the rear socket because back then I had some clear lights with a red light bulb installed. (but I had a green light on the dash)
Check the bulbs or replace them, check the socket or it could be the turn signal switch but that should not affect the break lights?
I found this, see if it helps!
http://wiki.answers.com/Q/FAQ/1119
This happened to me, after I got my HU installed for the first time.
It fixed itself after about 2 days, magically.
did you by chance have a new radio installed?. If so, check for loose wires.
Thrice . wrote:i think you should go back and try to actually order some cam valves. see if he has any in stock. then ask him to give you an actual price and show you the website or anything legit about where he orders from...for all you know he is this dumb, and orders things that don't exist....he's probably got 10 of those ebay transistors that gave him eleventy hundred pony power....what a douche.
No change in stereo.
I changed the GREEN flasher, where is the second located?
