hello to everyone!
i have these three codes coming up when i hooked up my scanner anyone have any clue what they are:
p0137 circuit low volts
p0480 cooling fan 1 control
have no clue need to no asap!!!! thanks guys for the help
Jonathan
just turn the radio up, itll be all good
sorry for no helpful input, these lunchtime drinks got me in the trashcan.
best of luck
wow that was no help! thanks though
sounds to me you got some sensors needing replaced.
1.)  p0137 is one of youre O2 sensor are needing replaced.
2.) DTC P0480 Cooling Fan Relay Control Circuit - Engine Coolant Temperature (ECT) sensor.
Intake Air Temperature (IAT) sensor.
A/C selector switch.
A/C refrigerant pressure sensor.
Vehicle Speed Sensor (VSS).
Those would have to be checked for faulty sensors. Also check  fan relay fuses & relay switches.
Good Luck.
