Ive got a 2001 cavalier ls, 4 door, 2.4L, auto. Ive got this code coming up. I changed the gas cap (mostly because it was the origional and looked to be in crappy shape). I know the previous owner had some evap work done but im not sure what was changed, i havent had a chance to go poking around under neath yet. Any thoughs or sugestions? It hasent affected the driveability at all.
I have found these codes are usually a leak in the system-I don't have my book here but if it's emissions leak the dealer can do a smoke test but If I remember correctly the purge valve on back of the engine, the vent valve by the tank, were all suspect to cause this. If you don't have any luck I have alot of info on these at home from when I worked at the dealer-reply back and I'll look
This answer has been posted many, many times. This is a good subject to help you acquaint yourself with the search function of the site.
purge valve
"A goal without a plan is just a wish"
from videos on youtube i heard when you get 0440 is when you don't have enough vacuum. i too have this code comes up every other few months.
~1996 Cavalier LS 2.4L (auto)
