I was driving today when my car began to sputter and eventually died as if out of gas. It has plenty of power and fuel, I just changed the fuel filter on the side of the road but no luck. I'm also sure there's pressure in the fuel lines. Please help what could it be?
well, get into car and press gas pedal to the floor and start. Does it start, if so, change your IAC Valve. If not then a possible Ignition pack/coil problem. Goodluck tho!
is your fuel pump priming when you initialy turn it to the running position? or do you have pressure in the fuel pressure relief in the fuel line by the rail?
If not, could be your fuel pump?
Buddy Club Ecotec Cavalier
* More to come *
1. any dtc's
2. cranks but no fire?
3. sounds like it has compression while cranking?
4. you need to actually monitor the fuel pressure to diag.
