Hi,
I've been through the very informative A/C sticky, and I have a specific question about replacing the A/C compressor.
I had my 2000 Cavalier Z24 into the dealer to get the A/C system checked, and they told me the compressor was dead.  Quoted my like $850 (Canadian) to fix it.  Wow.  I didn't totally trust them, so I took it into a recommended specialty shop to get another check.  Same result.  They quoted a rebuilt compressor (including accumulator) for about $700.  So, now I'm out about $175 for two checks and nothing to show for it...
Anyway, I made some salvage yard calls and found a used compressor off a 2000 Cavalier for $150.  Now, the specialty place said they would install it, but was claiming that they've never seen a used compressor that didn't leak.  Apparantely the gaskets are prone to leaking if the car has been sitting too long in the salvage yard.
So, I can risk it, and get it installed with no warranty for about $350 including the part.  If it doesn't work, I can return the part and just be out the labour ($200 or so).
Does anyone here have any advice for me on this?
Thanks!
buy a new one and put it on yourself..
you will probably save a ton....and used compressors are not a great idea..it will not last.
