all lights work except for rear right signal light, the same light that shows the brake shows the signal light doesnt it? so why does the brake light work but the signaler doesnt?????
when i turn the signaler to the right the arrow on the dash blinks crazy fast if that helps any, thats how i found out i had a bad light.
help plz!
When you turn the lights on and then hit the brake the light works ?  BOTH filiments ?
But then no turn signal ?  Is that right ?
If it is then the only thing that would make any sence is either a broken wire somewhere for the blinker or a bad turn signal switch.  Since the brake filiment lights when the brake is applyed then its good and since the running light filiment lights when you turn the lights on then its not the bulb or the socket the onlt things left is wireing and the switch itself.
Semper Fi SAINT.  May you rest in peace.
