Im working more on my engine now. I have a 1999 2200 Cavalier. I have a cold air intake. Header full exhaust and  mounts(on the way.) Other than internal stuff where should I go now. I pplan on waiting until next winter to do internal engine.
I would suggest a bored throtte body, light weight crank pulley, I dunno those are a few ideas but you need to read the FAQ and also look around in other peoples profiles and look what they are running to get some ideas.
<br><img src="http://memimage.cardomain.net/member_images/8/web/728000-728999/728095_1.jpg">
Yes officer I knew the speed limit was 50
try to upgrade ur ingnition, you got more air going in and out. new plug wires and look into making or buying an engine grounding kit.
those ground kids don't add any power at all, don't waste your money. get yourself a crank pulley, Denso iridium plugs and new plug wires, upgrade your ignition, bored TB, RSM intake manifold, and then start looking into forged internals.
denso's are pretty cold for a stock engine, stick with ac delco until you go either high compression, turbo/supercharged, or start using nitrous.
