i have a full system pacesetter exhaust, lower and upper engine mounts,pos matrix short ram air intake, some drilled and slotted rotors and about 700$ to spend.
does anybody know what i should do next im thinking about turbo i need the kit for under 1500 anyone nowhere to get one. i have 100k miles should i be thinking about internals.
if you want to boost i would start thinking about internals. whether you want to go forged and run boost or just do a stock rebuild and run 8 pounds, it's up to you.
what are you running at the track with those mods
start on internals.  i think  forged Eagle rods and new pistons come to around $700 on some sites
i dont have any time im only 14 i was thinking about buying a 2.4 from a junkyard and rebuilding it on stand then dropping it in when it was done so for now how about mods that dont require rebuilding the engine besides cams.
i think cams would be the next logical step.  and would run around $700.  aside from that i'd say to go with peicing together fuel mods MSD pump, psi regulator, injectors, exct. for your up and comming boost project.
or you could blow it on an intake manifold.
if you plan on going turbo you better work the inside first. With 100,000 you're asking something to break.  Then the next thing you know you can't run the car cause the turbo blew it up.  Then you definitely have to tear the engine apart.
if you are boosting, it's either all or nothing man. that's how i look at it. you can do a bolt-on turbo system and run 6 pounds safely forever, but it's not going to be really... THAT fast for a turbo car.
OR you can start byilding the motor, which allows for more boost, but more boost means more fuel. you also need then upgrading intercooler and intercooler piping, larger exhaust piping, blah blah. more fuel needs control so you need tuning. then you realize you need drivetrain work because stock drivetrain is not meant to handle it. oh and you might still after that want your car to look good too lol. it turns from $3k to $10k really... really quick.
