Ecotec intake mounting ????s + First posted pics - Performance Forum
Monday, October 10, 2005 6:23 PM
Alright first of all I just recently got my cosmoracing intake. It has a bracket right before the last bend by the filter.
as you can see that bracket looks as if it will go right into the power steering resevoir. Also, the bottom of the intake hits the positive terminal on the battery. If anyone has any help that woulb be SUPERB!! Thanks. And here are a couple pics of me and my brothers rides I took real fast the other day.
I will post bigger ones later this week.
thats it for now. enjoy.
Re: Ecotec intake mounting ????s + First posted pi
Monday, October 10, 2005 6:58 PM
i was considering this intake just because of the price, but if there's fitment issues i may have to pass, let us know how it works out, thanks
Monday, October 10, 2005 7:50 PM
just drill a hole into the bracket below the power steering pump bolt that you tried to hook the intake onto. Thats what i did, if you drill out a hole and then attach the intake bracket to that it moves it down and away from the battery. I also had problems with hooking it directly to the power steering pump bolt by not being able to tighten the bolt all the way cause of the thick bracket on the intake. Hope this helps.
www.chevyridez.com
Monday, October 10, 2005 10:39 PM
yea well its late at the moment but ill be sure to ghetto rig it somehow tomorrow. if im gonna have to zip tie this bitch on then thats what ill do.
Tuesday, October 11, 2005 1:15 PM
it sounds like you are trying to mount it to the wrong spot. Sounds like you are trying to mount it too high.
Here is a pic of my RK intake and where/how it mounts and lines up. Hopefully this helps. The bracket needs to bolt to the lower, larger bolt.
Wednesday, October 12, 2005 6:49 AM
ill try toying with it again, but also my rubber elbow is exactly that, one bend, very small. if i fail again ill post more pics.
thanks for the help everyone.
Wednesday, October 12, 2005 12:56 PM
rick weissbach wrote:ill try toying with it again, but also my rubber elbow is exactly that, one bend, very small. if i fail again ill post more pics.
You can rotate the intake assembly downward so that the bracket lines up where it should. Just don't tighten the clamp on the rubber elbow until it is positioned right.
