that sounds about right for a price
get them
lower mount is like 40$ ish. upper is 15, tranny mounts are 50.
YES, worth every penny, got em about a month ago, except I had to get the eco upper as well, vibes are kinda harsh at first, but they calm down after the break in, and you get used to em.
All I have is lower engine mounts, and I like them. When flooring it, the engine feels a lot stronger and more stiff then before. As stated, there is a vibration, the vibration has it's bright sides though.. my lady said, "It's like one big vibrator.. a vibrating car." The vibration isn't that bad.. only at idle and sometimes at low rpm. The mounts don't put any pressure on your engine like other mods, they just give you more horsepower to the wheels that you would usually lose.. which to me is a realy good deal. Squeezing out all that unused power is a must is you want to run your car's full potential.
http://www.cardomain.com/ride/2208703
the only time vibes are bad are in the lower rpms or going up a hill at either a high gear or low rpm.
When accelerating and cruising you wont even notice
Worth the buy!!! You will stop noticing the vibes quickly....
JON COLBY the poster of this topic, his engine mounts are already worn, (stock) do these replace those? or will he have to replace the stock ones too?
not sure to understand the question, but the mounts that he found on ebay will replace the lower one and the upper one is an insert, meaning that as long as the structure of the upper mount is still like brand new, he just replace the insert..
i installed my upper and lower mounts on my car. huge diffrence and im happy it was one of the first mods i did.
however around the upper mount i also sprayed expanding foam in the rest of the gaps around the mount......boy was that a mistake....you think youve seen a vibrating car? yeah....try doing what i did.
but the engine doesnt move
and to be honest it only really vibrates at above 80 mph when accelerating.
- Cameron (CaliforniaCavalier)
www.csc-motorsports.com (my new NOR-CAL car tuning site)
It does its job...worth buying.
Hope my upper mount insert comes in the mail today from Karo. Looking forward to install as much as everyone else is about theirs
. Of course my dumb ass ended up spending more becuase I only had enough money for the upper mount, then SURPRISE I got a little more money out of nowhere, and got the lower mount separate... wasted a few bucks when I could have just got the "kit" with both.
Grr I'm so blond.
totally worth it and it takes no time to install. Steve( custom97sunfire) and I did it in less then a half hour.
"Boost tuning"....... have you had your 8 PSI today?
future name of the winter shop!!!
...go with aaron from turbo techs offer. he gives great service, and youll get a good product. gonna be buying some suspension stuff and brakes from him soon.
oh, and i have both mounts, and like em a lot.
...don't hate!.. respect people that have talent, even if it is in something you don't like or understand.
the ones on ebay that Jon Colby posted....is it like universal....for the 2.2 and the 2.4!?!?!?......or are they diff....!?!.....jus askin cause i'm thinkin of gettin ...some myself!!!! thnx!!
The 1995-02 (2002 year does not use the same upper mount for the ecotec) are all the same.
All 1995-05 J's use the same lower engine mount, and 5 speed trans inserts.
2002-05 ecotec uses a different upper engine mount.
-Aaron
www.TurboTechRacing.com
One of the best mods you can do for the price!
Only engine mod I have ever needed.
Team GREEN
Suspension Division - "Handling Before Horsepower"
Making the turns since 1999
1998 EK Civic Hatch - Yes, it's a Honda.
Not the only one I ever wanted though, just to clear that up...
P.S. Jake, you idiot. E-mail me or something. I am rotting in the desert here and you don't bother to call. MattBall MattBall.
Team GREEN
I don't have them, but I sure wanted them. I will get some eventually.
Definately get them from Aaron. Turbo Tech Racing is a great business to deal with.
get them, it doesn't really vibrate bad unless your in too high of a gear for your speed. I love the feel now as I go WOT, feels like a more expensive sports car. all 140 or so(still need to dyno with my boltons) horses being unleashed....
yes you'll like it.
-Chris
listening.......
I've been researching this also. I have had some say that it is not worth it and others that say best mod next to a B&M Short Throw.........
My little brother has them, added onto his lower motor mount. You'll hear some transmission whine with them installed, but there is a difference in response time as the transmission doesn't first move, then apply power to the wheels. A lot like when you did your lower motor mount.
-Chris
