I have a '97 Z and I am currently upgrading my exhaust from the header back and here is what I have so far: pacesetter ceramic 4-1 header, magnaflow 94035 cat, and a dynomax thrush glasspack resonator (25" length, 2.25" in/out). I am looking to replace my current 2.5" catback, since I hear 2.5" is too big, with a 2.25" setup and from what I hear magnaflow is the way to go. I'm wondering if need to get the full magnaflow catback system or whether I should just go with the rear section and get custom piping? I know that the magnaflow rear section with the muffler that they sell at RKSport comes with an inlet pipe but will that be enough to make it back to the resonator? Also where can I find the magnaflow system for cheap? RKSport is a little pricey.
"Kneel before ZOD!!!"
I wouldn't even bother with a catback system, just take it to an exhaust shop and get one mocked up for you. It'll probably end up sounding better, but not only that, it should sound better to your wallet as well.
I second that. I just went in to the local Pro-formance exhaust shop here and ordered a Magnaflow muffler and resonator and had them install it. Sounds awesome!
The only reason why I mentioned the rear section is so that I can get some pre-bent piping because I'm trying to avoid going to a shop. All I need is enough to get back to the resonator. I have all the tools needed and access to a welder for install, but would it just be easier to take it to a shop to get it installed? Just trying to save some cash from having to pay a shop for the pipe, welding, and labor.
LD9 Fury! wrote:D-LuxZ24 wrote:I have a '97 Z and I am currently upgrading my exhaust from the header back and here is what I have so far: pacesetter ceramic 4-1 header, magnaflow 94035 cat, and a dynomax thrush glasspack resonator (25" length, 2.25" in/out). I am looking to replace my current 2.5" catback, since I hear 2.5" is too big, with a 2.25" setup and from what I hear magnaflow is the way to go. I'm wondering if need to get the full magnaflow catback system or whether I should just go with the rear section and get custom piping? I know that the magnaflow rear section with the muffler that they sell at RKSport comes with an inlet pipe but will that be enough to make it back to the resonator? Also where can I find the magnaflow system for cheap? RKSport is a little pricey.
Wouldn't bother getting the Magnaflow "rear section" or cat-back. Just the muffler you like, the glasspack, and tell the exhaust shop you want 2.25" piping.
Besides, even the single exit Magnaflow cat-back is in the $600 range depending where you look, and that "rear section" deal is overpriced too. Buy muffler, glasspack, and get pipe bent by shop and you spend about half that much.
where u shoppin man... rk an karo sell rksport catbacks for 300 new.. an i jus sold mine used for 170 shipped..
-marc
boosted again...hehe
Lets see, I just had my exhaust redone using my own cat and muffler. Total with tip, pipe, labor was $190.
Thanks for your help guys, I've just one more question. Is the muffler that comes with the RKSport Rear Sect. good? Does it have a nice deep tone? If not is there another magnaflow muffler that is better? Thanks again.
