Upper Engine Mount Ecotec - Performance Forum
Thursday, April 20, 2006 6:36 PM
I was wondering if anyone could give me a pretty detailed set of instructions for installing the upper mount on an eco. I saw the post in the eco build plan but the directions were for a z not an eco.
Re: Upper Engine Mount Ecotec
Thursday, April 20, 2006 6:39 PM
An eco is an eco, Z24 or not. Instructions are the same.
Thursday, April 20, 2006 6:44 PM
Takes about 15-20 minutes to do it.
1. Jack up and support engine with a wood block on a jack.
2. remove the coolant tubes for the reservoir.
3. move reservoir out of your way a little(1 Bolt)to remove.
4. remove the 4 - 5 bolts that hold on the stock mount on.
5. remove stock mount and install RK upper mount easily slide it in.
6. put all the stuff back together.
7. Remove jack and block of wood.
8. Start car and enjoy the vibes you get.
9. Check dash for additional screeches and stuff you never notices before.
10. Turn on AC and experience the turbo shake of the chassis on the J.
11. Be safe...ask someone for help if more is needed.
12. Ignore steps 8 - 11.... .
Silver Stripey makes your Day!
Thursday, April 20, 2006 7:33 PM
Thanks for clearing that up. Looking forward to all the new noises
Friday, April 21, 2006 4:43 AM
Youre welcome
Friday, April 21, 2006 8:31 AM
this may turn out to be "easier said then done" if you have trouble cause u dont have "power" tools i used a "breaker bar"....just an option if ur haveing trouble...Goodluck!
Tuesday, June 13, 2006 8:56 PM
so do I remove the old mount or leave it there and add the insert??
j
Tuesday, June 13, 2006 9:27 PM
The ecotec mount is super easy. You don't neet to remove the coolant resevoir.
Support engine from the bottom.
5 15mm nuts.
Pull mount out.
Wednesday, June 14, 2006 1:54 AM
I had to remove the resevoir top get the mount in and out... if I had about a 1/2 inch more I would have been fine.
Crystal: only the 2200 & 2.4's have an insert, and you have to take apart the upper mount to add in the insert. This can be done in the car, but is easier out of the car. The upper engione mount on the Eco is a complete replacement.
Wednesday, June 14, 2006 4:35 AM
it is a 2.4.
so it is just an insert. Thanks guys
j
Wednesday, June 14, 2006 4:21 PM
Just make sure you support the engine well from underneath. I did the upper mount on my buddy's ECO and it ended up taking a lot longer than it needed to. Even though I did support the engine, it still shifted and we had a hell of a time getting it back into place to get the mount bolts lined back up.
Probably what I did wrong, looking back on it, was just using stacked blocks of wood where I shoul dhave used a jack. (Although the jack we had would not fit under the car due to his body kit.
Anyway, moral of the story, support the engine. This job is actually quite simple.
Wednesday, June 14, 2006 7:23 PM
#5, could also use the Turbo Tech Racing insert as well. Same thing and comes in MANY different colors.
Wednesday, June 14, 2006 7:51 PM
I got the rk lower and upper eco mounts and the vibes are nothing at all compared to vivbs from a 2.4 or ohv, I love it!
Don't buy from MANTAPART!!
Wednesday, June 14, 2006 8:28 PM
i love the new vibes....wen i start the car my dash shakes...feels like i just turned the key to a muscle car....i love it........
and u dont need to support the engine....just pull the bolts off...move the resevior and slide the mount into place...use liquid soap to help it fit into place
you scratch my ride IMA EAT YO CHILDREN
Thursday, June 15, 2006 3:36 PM
Cavgold96 wrote:and u dont need to support the engine....
I disagree, if you get lucky then yeah you don't need to support the engine..if you are unlucky, trying to install the mount on an unsupported engine (especially with a stock lower mount) will eat up a lot of time if it shifts while trying to install the new mount.
Thursday, June 15, 2006 4:04 PM
I think he was referring to the pre ecotec mount.
